How can i change my 1 tb desktop hard drive from ntfs to fat 32 my computer has windows xp installed using the ntfs system i'm trying to add the hard drive to my media player its an inca hd media player with memory card flash drive support to be able to play on my t.v. as well as a usb dock for portable hard drives hard disk format support is fat32 multi-partition which i thought this drive would be capable of using.
    Scholar:
  • 108 Answers
You cant...you will lose operating system. xp will not work on fat32 partition...AND xp is meant to run on NTFS system...just buy the external hard drive..they are cheap nowadays...i got one for 139 bucks....and store all my stuff on it and leave my 320 g hdd open for whatever then archive it onto the 1tb when i need to.
Posted on Sep 24, 2009
  • 360 Answers
NTFS is big files and folders. FAT 32 has its limits. Maybe it is but, disconnect everything during setup and installing. I mean everything except keyboard and mouse and master cd/DVD.
  • 50 Answers
The only way to change from NFTS to FAT32 is formating the hard disk.
You will have to install everything again after format it.
    Sergeant:
  • 191 Answers
To convert a drive from NTFS to FAT32 you need to use partition magic program
I need to replace the (failed) HD with a Seagate 80GB which is currently formatted FAT32. Is this OK or do I need to reformat as NTFS? Using WinXP
I'd use NTFS but you can make up your own mind here....
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/choosing_between_ntfs_fat_and_fat32.mspx?mfr=true
If you have old computers that need to access files on yours go FAT or FAT32. If you intend to or would like to add huge hard drives in the future (over 2 TB) go NTFS.
Regards
TickMagnet
Aug 19, 2011 | Dell Dimension 2400 PC Desktop
My new Toshiba STORE ART 3 1 TB external Hard Disk is not working. i plugged it to my pc on windows 7. and it shows the drive in My Computer but when i opened it it saying that 'Please insert disk into...
Open your command prompt and format the drive type format volume [/fs:file-system]
volume: Specifies the mount point, volume name, or drive letter of the drive you want to format.
/fs:
file-system: Specifies the file system to use FAT, FAT32, or NTFS Floppy disks can use only the FAT file system.
Example.........FORMAT E: /FS:FAT32.....Press enter. E: is my second drive
May 19, 2011 | Computers & Internet
Formatting a Fantom G-Force drive from NTFS to FAT 32
my computer> right click on the terabyte> select format> make sure u change the option of ntfs to fat 32
May 27, 2010 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
Hi i got gx270 and i made a bootable acronis disk director on a flash so i can format ntfs to fat 32 as i tried before to install win xp from a flash drive but got a stop message sayin i should check...
First of all I have to ask why you are trying to load FAT32 instead of NTFS. NTFS is the preferred file system for all Operating Systems after Windows 2000. Also, you cannot format the hard drive through the Windows XP installation for larger than a 32 GB partition. If you need a larger partition, I suggest using a floppy drive with the3 WinME bootdisk loaded on it. You can get it here:
Try the WinMe bootdisk from http://www.bootdisk.com/bootdisk.htm
If the above is not the issue than we can move forward with other solutions.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell OptiPlex GX270 PC Desktop
I want convert ntfs to fat 32
the convertion from ntfs to fat32 will result in loss of all data in the drive (all data from desktop,my documents, installed programmes.......). You can do this using your windows disc . Just set the primary boot device to be cd-rom in the bios,boot with windows cd in drive,then the installation will guide you to the insallation of a fresh copy of windows (there you can select the required file system).it is recomended to continue with ntfs
Feb 28, 2009 | Microsoft MS Windows XP Professional SP2
Operating system
had same problem . try reformating the hardrive in fat 32 system instead of ntfs it worked for older hp
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
I formatted my 1TB usb drive into ntfs want it back to fat32
If this is your bootable drive that windows in installed on you will need to completely reinstall windows to convert it back to FAT 32. If this is a spare drive then you can right click the drive in My computer and go to format and then reformat it as Fat 32.
Dec 20, 2008 | Western Digital MyBook Studio 1 TB USB...
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Computers & Internet Logo
529 people viewed this question
David Payne
David Payne
