Question about Hitachi 43FDX01B TV
Hitachi Tube TV, 1994, 31", model 31DXT1B. Problem is the top third of the screen is distorted in that it will take the top third of the image and wrap it over itself (horizontally). The distortion height at the top of the screen seems to vary from time to time, from 25% to 40%. At first it would happen and then not happen. Now it happens all the time distorting 25% to 40% of the top of the screen. This happpens on all inputs (RCA, Coax, S-video). Thoughts?
  • rich06082 Sep 24, 2009
    There are approximately 100 capacitors. I would need to identify the "Vertical Deflection section" to remove and replace those capacitors. Can I post or email pictures of the circuit boards of the TV to identify the "Vertical Deflection section"?
    Can I post or email photos of my circuit boards to determine the "Vertical Deflection section" section?
  • 10,594 Answers
This kind of problem occurred in TV when one or more electrolytic capacitors in Vertical Deflection section becomes dry/ leaky.
Please replace all electrolytic capacitors in vertical out section in TV, these would be around 6 or 7 capacitors and TV picture will be fine.
If you are handy with electronics stuff repair and can solder parts in circuit board then do it yourself OR contact local TV tech to do the job.
Thanks.
Posted on Sep 24, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 24, 2009
    Please email pictures at welcomejee@yahoo.com so I will mark these capacitors.
    Need to identify vertical output IC, once its done, check nearby capacitors that has shrink plastic covers, replace them.
    I just replied your email.
Multimedia projection tv distorted picture
IF IT'S A 3 TUBE PROJECTION TV, THEN THE COVERANGE IC'S CHIPS BAD
Jun 26, 2014 | Televison & Video
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi C21 model.The colours on screen have got scrambled.
It sounds like something has left a strong magnetic field on the face of the picture tube, and that's causing the colour distortion. The electron beams from the tube's colour guns are hitting the wrong spots on the face. There is a degaussing circuit in the TV that tries to neutralise such fields every time the set turns on. Sometimes electrical equipment (particularly motorised appliances like a vacuum sweeper) operating too close to the TV can leave a field too strong for the degaussing circuit to cope with. Or a failed part in the circuit may have made it inoperative.
A hand-held degaussing coil can be used to remove the field. You can purchase one online, or call a TV service technician. It used to be a standard tool to carry.
Another possibility is that the tube has been damaged. There is a very thin metal mesh screen called the shadow mask behind the face of the tube. If this mask has been warped by a strong magnetic field or a mechanical shock (if the set was dropped, for instance), you will see the same colour distortion. In this case, however, there is no repair other than tube replacement. And that is likely to cost more than a new set with parts and labour.
Jul 26, 2010 | Hitachi C21-F200 21" TV
Hitachi 43FDX15B distorted picture. The top of screen displays a half circle cirle and the image is distorted within the half circle. The same at the bottom of the screen. The middle of the screen is fine....
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 11, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Ghosting or distortion on edges of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Hitachi 43F300 43" Rear Projection...
Hitachi C50-FD2000 Screen Distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jan 02, 2009 | Hitachi C50F200 50 in. Rear Projection...
Distortion and double imaging
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Double images on top third of sceen
Faulty alignment mechansim or colour wheel. Expense unknown.
Oct 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 43FDX01B TV Logo
63 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
