Question about Kenmore 75944 Gas Dryer
Dryer barrel turns no heat this is a gas dryer 90 series kenmore
I cannot seem to find out where the fuse or ignitor are on this dryer or how to remove the front kick plate. Not sure what could be causing the dryer to fail heating up gas supply ids good exhaust is lint free along with the trap located in frnt by loading door anyone have suggestions
    President:
  • Kenmore Master
  • 1,922 Answers
Remove front cover, this will allow you to remove top cover, then take off drum belt and you will see the gas valve,follow the gas tube to the fire funnel and you will see the ignitor, check for continuity, if its good, then it could be a flame sensor or the control board at fault
Posted on Sep 26, 2009
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 90 series gas dryer no heat
The gas ignitor most likley is not functioning. They do not have a pilot light like appliances in the oold days. They must ignite a new flame each use. if you don't smell gas when you try and use, then it is the ignitor and the computerized sensor tells the gas not to turn on because the initial flame has not been created.
Oct 08, 2012 | Kenmore 63942 Dryer
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Sears Kenmore 90 series dryer
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 17, 2010 | Dryers
Need help with gas dryer Kenmore 90 series serial #MK0211114 the gas does not ignite electric is working fine
This could be several things thermal fuse,hi limit thermostat,flame sensor, ignitor,or coils. There is a video on troubleshooting a gas dryer at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting procedure. It is a different model but troubleshooting will be the same. You could also check the video on the electric heating element replacement that is a kenmore 90 and most of the parts will be the same. That one will give you a good idea of what thermostat is what.
Mar 24, 2010 | Kenmore 73952 Gas Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Kenmore 75944 Gas Dryer Logo
267 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
