Question about Kenmore Vacuums
I have a Kenmore Canister Vac. I need to replace
I have a Kenmore Canister Vac. I need to replace the swivel assembly on the power-mate floor attachment. How do I remove the old one?
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Posted on Jul 30, 2010
Beater bar turning on and off. Why doesn't the vacuum?
Try wiggling the wire and where the hose swivels to attempt to determine where it may be shorting out. It could be the wire or the plugs where the wires connect if your model has them. Inspect these areas closely to find your short.
Apr 08, 2016 | Kenmore Vacuums
My husband accidentally dislodged the belt on my kenmore canister vac. how can we disassemble the head to put the belt back on?
There should be 4-5 screws on the bottom of the brush assembly, remove them and you will see the brush and belt, remove each end of the brush assembly they should lift up and out of the housing,and either replace or reailine the belt on the motor side of the housing.
Aug 25, 2014 | Kenmore Progressive Canister Vac Cleaner...
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Central vacuum power head no work
Looks like a Beam central vacuum www.beamvac.com, and a Kenmore vacuum head.
Reply what problems you are experiencing and I will try to help.
Jan 23, 2009 | Vacuums
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore canister vacuum #116 5521290
im not familiar with kenwood vacs (i'm in uk not us) but usual cause of this type of fault is a fracture in the power cord where it enters the appliance or at the cable clamp. cut 6ins of the power cord and remake the connection
Aug 31, 2008 | Vacuums
Won't power on.
It maybe cheaper by going to somewhere like the Radio Shack to get a fuse. Take the bad fuse with you and they should be able to fix you up with one.
Jan 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
238 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
