Question about MSI P6N Diamond Motherboard
Installing new k9n2 MB, cannot connect to existing std svga monitor as DVI o/p only and no adaptor available, used hdmi adaptor to connect to hd tv, - no signal detected what do I do next plse?
  • phil_hewitt Sep 24, 2009
    I have tried this a number of times,
  • 360 Answers
Try resetting everything. Turn-off and restart computer. I know someone who has HDMI DVD and media center and that is what they do. I'll flip if it works!
Posted on Sep 24, 2009
  • 1 more comment
  • Richard Klein
    Richard Klein Sep 24, 2009
    No other TV or VCR with those connections?
  • Richard Klein
    I know you said you shut it off. Did you unplug hit power button, then plug back in?
  • Richard Klein
    Richard Klein Sep 30, 2009
    The best solution is changing the adapter. There may be a compatibility issue with the HDMI.
Looking at purchasing a used HP MP3135. In purchasing a HDMI female to M1-DA male adaptor, will this allow me to connect my laptop etc via HDMI cable? We also would like to connect a Wii and HD TV, how do...
HP available M1 to VGA (included )
Optional M1 to DVI (available on HP accesories)
To connect laptop via HDMI to Projector you need a HDMI to DVI adapter + Cable M1 to DVI (you get ONLY Video on DVI Output)
To connect Wii to projector you need a M1 to Composite
look the manuals on page 20-30
You can download the user guide on
http://h10032.www1.hp.com/ctg/Manual/c00063031.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | HP mp3135 Multimedia Projector
Turn on ps3 i get no picture or sound then i cant turn it off i have to unplug it whats wrong with it?
  • Check your HDMI Cable
    HDMI is available in several versions. The PS3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PS3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PS3.
  • Cable adaptors (i.e., HDMI to DVI converters)
    If you are using an adaptor (i.e., HDMI to DVI converter), try bypassing this adaptor and connecting the HDMI cable directly into the display.
  • Check the adaptorTry an alternate cable
  • Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HDMI setup and/or equipment.
  • Some older HDTVs may have issues with the copy protection protocols (HDCP) causing the handshake not being communicated between the TV and the PS3. Try resetting the TV by turning the TV and PS3 off, then unplug the TV power cord from the outlet and plug it back in. Then turn your TV and PS3 back on and see if the picture appears.
  • Try using a different the HDMI Cable on the PS3.Make sure the HDMI Cable is free of any cuts, frays or other visible damage.
  • Try installing the PS3 to another TV or display (i.e., monitor).
  • Try using the HDMI Cable with a different PS3 system.
Aug 18, 2011 | Sony Playstation 3 (PS3) Console
Hi I am trying to connect a Dell Latitude E4310 computer to a HD Vizio TV. I know that I need a HDMI cable to plug into the TV But what should the other end be? or what adaptor do I use to connect with?
HDMI cables will have either HDMI or DVI on the other end to plug into a flatscreen tv. If you are trying to plug it into an older tv without HDMI or DVI, you will need an HDMI to whichever plug is available on your tv. http://www.amazon.com/GefenTV-HDMI-to-Composite-Scaler/dp/B0013LTNF8
Jun 28, 2011 | Computers & Internet
Installing new Samsung BX2250 21.5 widescreen monitor, don't have the appropriate DVI outlet on my computer to match HDMI to DVI cable supplied with unit. Monitor is stuck on "Check Signal Cable...
Your monitor has Analog RGB, DVI and HDMI inputs. Any other hook ups will require additional cables and/or adaptors. It also has 2 additional audio inputs. I can't answer your question without knowing what kind of outputs you do have on you computer system. Most desktops have DVI out and would probably be your best bet using a DVI to HDMI adaptor with a HDMI cable out to your HDMI in on your monitor.Rgb cable would use svga out on your computer. The best way to get an answer would be to let me know the make and model of your computer system with avaiable outputs, if you know what the outputs are or, repost with additional info included.
Dave
Apr 30, 2011 | Samsung Computers & Internet
Hello, I got my MSI Hawk 5770 and it works great on DVI connection. The problem is when I use HDMI output from the card, its definitely displaying incorrectly, like its the wrong resolution. I try to go...
Hopefully you are getting your latest graphics driver and Catalyst Control from AMD. If you know how to do a custom uninstall of VGA and Catalyst, then a custom install of VGA and Catalyst;
http://support.amd.com/us/Pages/AMDSupportHub.aspx
You should really try to limit switching the cables and definately do your switching with system off or you will mess up your resolution. If you can use your existing HDMI cable for your PS3, you can get an ATI HDMI to DVI adaptor and you will get the sound also out of your DVI output. The connector is $5.00 and you will need an additional HDMI cable. This will be your best bet especially if you have more than 1 HDMI input on your tv. I am absolutely positive this will work for you. You can get the adaptor here #6141054300G;
http://www.txcesssurplus.com/servlet/Categories
Apr 25, 2011 | MSI Microstar R5770 Hawk RADEON HD 5770...
How to connect my pc to my tv & use it as a monitorbaxterstead000@hotmail.com
-get a vga cable(usually both ends are male) - connect it to the vga port on the laptop then the other end to your tv -press fn+f2 to switch the display to your tv( this is model/brand dependent, check your user's manual for more info)
Oct 23, 2010 | Computers & Internet
How to connect a pc to an Insignia tv NS-L22x-10A
you can do this with dvi to svga or sv or get a monitor to component cord or dvi to hdmi, i do this with 3 of my tv's, call me if u like 3363926682 if this helps please give my the max thumbs up
Apr 16, 2010 | Insignia NS-L22X-10A 22 in. HD-Ready TV
Dvi to hdmi no picture on hdtv
If you to have a newer tower that has a dvi trapazoid female receceptor.Read the small print
they may say digital ,but never mention HD Bastards!
Feb 05, 2009 | Toshiba Televison & Video
Ps3 doesnt connect to my computer monitor, how can i make it work?
Hey daashman,
According to information provided by the manufacturer, this particular Samsung model supports both VGA and DVI-type cable connections. The Playstation 3 however, does not currently support cables of either of these formats.
The good news is that there are ways around these limitations, typically in the form of a cable adaptor. Most models of the Playstation 3 should have an option for owners to use an HDMI cable to connect their TV or monitor, and many major electronic retailers often sell HDMI to DVI adaptors or adaptor cables of varying lengths.
If you're not quite sure what to look for, I would suggest checking out an online search engine for "HDMI to DVI adaptors." This should pull up a number of links that can provide you with not only detailed pictures, but also average pricing of the products available to you as well.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 02, 2008 | Sony Playstation 3 (PS3) Console
MSI P6N Diamond Motherboard Logo
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
