Question about Tomtom ONE 3rd Edition GPS
Everytime i turn on my tomtom f10 it showes a piture of the sd card with a cross through it. how do i fix this problem
  • kyledavies87 Sep 24, 2009
    can u please help me fix it
    Problem Solver:
  • 8 Answers
There is a problem with your sd card. try taking it out and giving the conections a good clean and push it back in but make sure you push it in as far as it will go, if this doesn't work try connecting it to your computer via card reader or usb cable. if you cant access it then it is ready for the bin.
Posted on Sep 25, 2009
When turn On can get the screen showing the GPS connected to Computer when not connected ,On Battery only, get red cross flashing
If your TomTom shows a red cross, it means the device is not able to load the software to be able to operate. Some devices have this software on a SD-card, some have it stored on an internal memory.
If there was a SD-card in your TomTom, I would suggest to put it back. If there is a empty SD-slot on your device, it could be you lost your SD-card, but some TomTom devices have an internal memory AND a SD-slot for memory extension, so if you have an empty cardslot it doesn't necessarily mean there has to be a card in it.
When you never saw a SD-card, probably some data went corrupt on the internal memory. When you have a SD-card, probably some data got corrupted on the SD-card.
To repair the software, you need to connect your GPS to your PC or Mac with a USB cable.
You also need the program TomTom HOME. You can download it for free on the TomTom website.
With TomTom HOME you can update the operating system of your device for free (map updates are nor free).
Try updating, and see if your device works again.
If this doesn't work, post it here.
May 14, 2015 | Tomtom GPS
The tomtom X-l doesnot start anymore. It shows the card taken out of the themtom with a red cross over it
If the sd card is in the tomtom then it has become corrupted, have you tried reading the sd card on a pc using a card reader?
Feb 24, 2011 | Tomtom ONE XL GPS
Tomtom shows a red cross over the SIM card and will not turn on.
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Apr 23, 2010 | Tomtom ONE GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
My tomtom one has a red cross across sd card when i turn it on
no that will not work see pullin the sd card out of the tomtom kinda pisses off the application if u have the red x error first do the soft reset if that does not work then update ur tomtom an application should pull thru as a download if not dont fret on tomtom home go to show contents on my one then delete just the application and i mean just the application then go back and hit update my one it will download and install new app and boom baby all done
Jan 20, 2009 | Tomtom ONE GPS Receiver
TOMTOM ONE
Unfortunatly that data on your SD card has become corrupt or the CARD itself had become damaged / faulty. Hopefully you had previously backed up your SD card to your PC ? . if this is the case all you need do is reload your tomtom files from the PC and onto your card. Hope this helps.
Jan 27, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom 300 software update deleted my maps
Hi Albert. Theres lots of data on the card besides the map that your tomtom needs in order for it to work. Theres really no solution can be offered as unfortunatly something has happened to the data on your card and something is either missing or corrupted. Exactly what would need to be investigated and its not really within the scope of doing so on this forum. Without any judgement to you or anyone else can I warn all other tomtom users ..... BACK UP YOUR SD CARD TO YOUR COMPUTER before you attempt any "update" to your tomtom. If you have made a backup Albert then I suggest you reload the backup onto your card and everything should work again. Fingers crossed. You might need to do a hard reset by pressing the reset button underneath your tomtom with a paper clip through the reset hole. Good luck.
Dec 29, 2007 | Tomtom GO 300 GPS Receiver
My gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
May 06, 2007 | Tomtom GO 510 GPS Receiver
Tomtom510
them two dont' work at all. please help. i earesed all the data of my tomtom go 510 sd card and i dont have a backup of them. does any one have backup files.
Tomtom ONE 3rd Edition GPS Logo
57 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
