Question about Fellowes Powershred SB-87Cs Shredder
Shredder will not atomaticly turn on when paper is put in.
  • 557 Answers
The micro switch is stuck or bad. It is located in center of the cutters. Unplug and check for scraps of paper jamed around the switch.
Posted on Sep 24, 2009
Testimonial: "Thanks I'll try that. Thanks D.C."
5 Suggested Answers
SOURCE: Aurora paper shredder AS1200X Parts
I called them and they were no help at all. They said, in short, "We don't have parts, we can't help you, buy a new Shredder! There warranty is 30 days with receipt.
I would buy yours for parts but it wouldn't be worth the shipping charges!
If you wanted to remove the micro switch and would send to me I'd be interested in purchasing it. My machine isn't that old, so I really don't want to purchase a new shredder. I got it from CostCo last year.
blendervill@yahoo.com California.
Posted on Feb 24, 2008
  • 6 Answers
SOURCE: Tech Solutions shredder
Here is the info that I found:
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
Posted on Jul 11, 2009
SOURCE: Shredder stops when paper put in
Solution: called customer support, who said "It's broken.? But, it was still under warrantee, so I sent it back for a new one.
Posted on Dec 23, 2009
  • 1218 Answers
SOURCE: I own a Royal RL170MX shredder. I turn on the
If the blades rotate then the paper should go in...just be sure the blades are turning in the forward direction and not in reverse.Also make sure you lubricate the blades with shredder oil.
Posted on Aug 22, 2010
Black n& DEcker paper shredder CC600 will not turn on
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Apr 18, 2015 | Black & Decker CC600 Shredders
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
The shredder makes a "horn" like sound before putting paper inside the slot
Many shredders will do a quick reverse to be sure that the path is clear.If the sensors detects NO PAPER it turns off quickly. If there is paper in the shredder, it would continue until the path is clear, or it will time out. I think about 15 seconds or so.
Sep 18, 2014 | FELLOWES SHREDDERS Datastroyer 1615 Ms...
Shredder will not turn off
Unplug the shredder from the power outlet. Remove the paper canister. You will need a can of air to blow all areas both from inside of the shredder around the blade area and outside of the shredder around the blade area. After you complete that part, Check the sensor area to make sure no paper is jammed around it. Plug the shredder back in and turn it on. If that fixes the problem, get a sheet of paper and put some shredder oil on it and put it thru the shredder for lubrication.
Apr 11, 2012 | Office Equipment & Supplies
I have an Aurora Shredder -- Model #AS1512X. Paper got jammed and I pulled the paper out and now the shredder will not work. Any ideas as to how to fix this?????
Check safety and detection switches. 1. Safety is on the bottom and left or right side of shredder unit inside a narrow gap. On the bucket's wall there is a natch witch should go into the gap, when you put shredder correctly. Check if switch and natch are on the same side. Simple turning around will solve problem. 2. Check a detection switch. It is located in the middle, inside of gap. This switch engages and turns motor on when you put paper into shredder. In other words sheets of paper should push the switch first before touching shredding rolls. If you have digged out that paper from the top side, chances are you have broken that switch.
Feb 12, 2011 | Aurora Electronics Office Equipment &...
Dec 22, 2009 | OfficeMax 0M96431 Shredder
I inserted paper covered with polythene and now the shredder wont start or turn. the polythene has tightly locked the shredder. it is a jielisi make.
There's only 1 true way to unblock the teeth, that's to put it in reverse to try to remove paper from the feeder channel. After that, unplug the unit, turn the head upside down and "dig" the paper out with a small knife, flathead screwdriver, or tweezers. The paper will come out a little at a time but eventually will come out in chunks. The only alternative would be to completely dismantle the shredder (not recommended).
Nov 17, 2009 | OfficeMax 0M96431 Shredder
Sep 01, 2009 | Royal Office Equipment & Supplies
Paper shredder
Shredders have a light emitter and detector inside the slot where you put the paper. When the paper is put in, the emitted light is reflected off the paper, detected, and then turns on the shredder by sending a signal to the control board. The emitter/detector often has a plastic cover which over time collects paper dust. The paper dust can reflect the emitted light back onto the detector, causing the shredder to remain on. You may need to remove the top of the shredder and remove the shredding mechanism to get to the light sensor. It's also possible that the components on the control board have changed value, causing the detector sensitivity to increase. This may result in the unit turning itself on in daytime and off at night.
Jan 15, 2009 | Fellowes DM15C Shredder
Paper Shredder will not shut off when in auto mode
if you answer no to the following question, then I do know your solution: Q: When you unplug the unit immediately after your action of "When those paper complete the shredder does not turn off."...and then plug it back in, does the shredder STILL continue to operate? if no, then the solution is to disassemble the feeder unit and manually unclog the paper sensor.
Jun 14, 2007 | Royal VF1012mx Shredder
Fellowes Powershred SB-87Cs Shredder Logo
140 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
