Question about Dell Inspiron 6400 Notebook
Display problem with colors
My display is having problem ... the white part is getting pink ... and i hav some green dots on screen
  • 3,940 Answers
First, reseat the video cable (Located under the keyboard) then, if nothing changes, try an external monitor and see if the issue occurs there. You can also run the Diagnostics Fn + Power Button and select N when asked if the video displays normally to initiate the LCD color test) If the LCD has issues in the diags, then it will need to be replaced. If issue occurs on external monitor, then the Motherboard is likely the issue
Posted on Oct 03, 2009
    Novelist:
  • 137 Answers
Check the display on the external monitor. if the display if fine, you lcd needs to be replaced. if the display is the same, your computer mother board has gone bad.
here is what you can also try before calling Dell.
Turn off your computer.
now, press and hold the Fn button at the bottom left hand corner. and then turn on the computer. kepp holding the Fn key down untill you see Pre boot self assesment. it will check all the hardware problems in the computer. After 2 minutes it will show you a rainbow. if the colors are fine press Y else press N. it will give you an error code. call dell and give the error code and get the LCD repalced.
Posted on Sep 24, 2009
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
Pink dots on screen
Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
Jul 27, 2010 | Toshiba Satellite X205-SLI1 Notebook
I need help I don't know what color wires go to what wires on my sterio deck
I have a radio wire connector on a 1994 Toyota Camary and the color don' match your list, here is my list.
2 reds, one silver dot, one double silver dot.
2 blacks, same as above,
2 greens, same as above.
2 whites, same as above.
2 browns, same as above,
1 white w/green stripe, two silver dots
1 black w/red stripe, one silver dot.
1 yellow, two silver dots.
1 blue, two silver dots.
the numbers on the connector are A02 16 14 11264 9 8.
I'm clueless which wire are which.
Oct 30, 2009 | 1994 Toyota Camry
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Jul 24, 2009 | Vizio GV42L 42 in. LCD Television
Tv problems need help
I had same problem
Apr 16, 2008 | Televison & Video
Samsung Plasma 720p HDTV hpt5034
If this is a new set, return it for exchange. This is a warranty repair item.
Dan
Mar 19, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Dell Inspiron 6400 Notebook Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
