Question about Tower Aloha Breeze Fan
I need Aloha plastic ring in back of fan that
I need plastic ring in back of fan that holds fan caseing in place for model#46051. Serial#0001045. The fan blade is in place but the ring that holds the wire case in the back of the fan is broken and I don't know where to get another one? The fan is the Aloha Breeze Vintage Stand Fan. Date on the back of the fan is 11/04. The fan worked great till this ring broke. Can I order this part or even get a replacement part?
    Problem Solver:
  • 8 Answers
Send an email to ahitexaslg@aol.com.
Posted on Sep 24, 2009
16" Vintage Stand Fan not a tower type Model #
first check AC power cord for cutoff wire inside. if its ok, carefully remove back motor cover and find FUSIBLE RESISTOR, its covered by insulator, replace it or connect two legs together or jumper-ed with wire, covered it with insulator like wire tape for short circuit purpose, then try it.
Aug 10, 2011 | Dryers
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
This fan is the Aloha Breeze 16inch Vintage Stand Fan made in March of 2010. Serial# 02299 model # 46052(46051) purchase order # 2082395186 UPC # 759590460526 it is the heavy chrome model. We have...
You are still in the warrranty period of one year and it is most adviceable not to tamper it so as to lose the priviledge.
So please get in touch immediatley with your dealer.
Only If there is no help do you need to open the base and check the leads from plug to the motor for continuity. if voltage is present then motor may be faulty.
Sep 14, 2010 | Vacuums
Aloha Breeze 16" Vintage Stand Fan Model #46051 (46052) Serial #03156: Trying to open up the case to get to the motor, to try and replace a fuse or something that's making the fan not work. I got the...
It isn't worth fixing. I am on my second one which didn't last any longer than the first which was about 3-4 months. These fan motors are junk. First failure was a bearing and when it started failing, it was noisy. Eventually, the fan would not start because the motor didn't have enough torque to overcome the friction in the bad bearing.
The second fan was quiet but has NO starting torque....no unusual for fans generally, but I'll NEVER BUY another ALOHA BREEZE product again.
Sep 08, 2010 | Tower Aloha Breeze Fan
pull it up and you will see a **** in it, take a screwdriver and pry it and it will come off, I've got mine apart but don't know what to do to fix it
Broken threaded plastic part to hold blade tight.Aloha Breeze Vintage Stand Fan Model 46051
Have you tried using the Evostik Superglue for Hard Plastics
It is brilliant for putting broken palstics back together again
May 25, 2009 | Tower Aloha Breeze Fan
Aloha Housewear company
If you open the shells of the motor you had void the warranty and aloha cannot help you. But if you only look around the switch housing and cannot find what's wrong with it just give them a call at: 1-800-295-4448. Good Luck!
Jul 07, 2008 | Aloha Housewares (93645) Ceiling Fan
Tower Aloha Breeze Fan Logo
463 people viewed this question
Top Tower Dryers Experts
Henry  Thomas
Henry Thomas
Jay Finke
Jay Finke
Are you a Tower Dryer Expert? Answer questions, earn points and help others
