Question about HP DesignJet 330 InkJet Printer
Film + error lights flash. I have replaced the ink
Film + error lights flash on my Designjet 330. I have replaced the ink cartridge and then used the plotter successfully but after not using the plotter for a few weeks when I turned it on to use again I have now got the same error code
    President:
  • 1,653 Answers
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
Posted on Sep 24, 2009
  • 375 Answers
This error code gives an indication that one of the cartridges are either faulty, misplaced or completely missing. Also it can indicate that the cartridges are all misplaced, making a bad contact or of a wrong cartridge model. The first step you should take is to replace the black cartridge. See that the Black Cartridge passes the test on account that it is not malfunctioning, misplaced or of wrong type. If it passes, I would suspect a malfunctioning Trailer Cable.
OK, I assume you have changed the Black Cartridge with same error results. The next test you should take is that try sending a plot wider that 36 or 24 inch ( as per the model's width { as some are of 36" and others are of 24" } ) and see that the second side is printing out fine with not problem. If yes, the black cartridge is the culprit and replacing has solved it. But if you see that the printer is flashing the ready light but not plotting then something is wrong with the Printing Parallel Port Mode. For this point only, make sure that the Printer Parallel Mode is correctly set into ECP on the PC BIOS.
Replace the Printer Cable which is not longer that 2.5 - 3.5 meters. The other point you can do is to check that the Printer Driver is up-to-date. You can check at www.designjet.hp.com.
Also try the self-tests. They are the Setup - test or the Demo - plot. If they are reported OK, then surely this is a Faulty Cable Issue.
Sir, I think now you can get it. Please reply me with your view.
Thank you Sir, Have a nice day.
Originally the black ink would not print. replaced, primed, cleaned. nothing, the same problem, no black ink. Now I can't get the cartridge light to quite blinking. It is not steady orange, but a...
First off, if you touched the metal contacts on the printer or cartridge, you could damage or leave a film on the contact surface. Take it out of the printer, with a qtip dip in rubbing alcohol, squeeze out access, rub surfaces, air dry, and reinsert again. If still no ink, turn the print end up under the very hot water tap and run for 2 minutes. Dry and replace. It may do the trick.
Mar 01, 2014 | HP DesignJet 450c InkJet Printer
My HP Designjet T1100 says "Ink Cartridge Faulty Replace Ink Cartridge". But the cartridge in brand new. Any suggestions?
The most common cause I've seen is that when people put the new cartridge, they forget to remove the seal which makes the ink stay in the cartridge. It is typically a strip that covers the hole where the ink comes out, or else a strip that is located far from the hole, but that needs to get removed or else the ink will not flow from the cartridge
Feb 27, 2013 | HP Designjet T1100ps Printer
Errorcode 93:11 on HP designjet 4000
Unable to pressurize the IDS(ink delivery system). Ink Pumping problem.
Corrective Action: Try the following:
Remove ALL the Ink Cartridges and reinstall them one by one in to the
Printer.
Replace the Ink Cartridges.
Replace the APS Assembly.
If the System Error continues, replace the Ink Supply Tubes and Trailing
Cable
Jul 15, 2011 | HP Designjet 4000ps InkJet Printer
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Cartridge light flashes ink drags across wide
The user manual says that indicator is for a bad ink cartridge.
But it doesn't say which one (so you have to check them all).
And it doesn't say why.
It recommends removing each, checking the contacts, and reinstalling the.
Otherwise is says replace the bad cartridge.
Nov 19, 2009 | HP DesignJet 450c InkJet Printer
My HP DesignJet 330 prints for the first 6" of 24x36 paper. Then the led lights start to flash. The printer keeps going, yet no ink goes on the paper
Guys
1. Thanks for coming up for air
2. We figured out the problem
3. It's a master panel board in the bottom right corner of the printer
4. At this time we will be throwing out this HP 330 and getting another
Thanks for your help.
Oct 01, 2009 | HP DesignJet 330 InkJet Printer
Hp designjet 450c error lights
Take all cartridges out while the plotter is on,then re-insert them one by one and watch the ready light flash after each insertion.If it doesn't flash that could mean 2 things,either the cartridge is bad or the contacts on the carriage are dirty or the entire carriage needs replacing.
I tell all of my dj-4XX customers to check the spittoon assembly(on the inside,right side)for ink buildup. If it looks clogged,you can temporarily scoop the ink that solidified out,but eventually it(spittoon)will need replacing.
Hope this helps
Jan 09, 2008 | Xerox Phaser 7750DN Laser Printer
Open Questions:
HP DesignJet 330 - plot from AutoCAD - page size problem From AutoCAD Map 3D 2006, I have created a viewport that uses a 24"x18" Landscape paper size for my Page Setup for plotting to our HP 330 onto a roll of 24" wide mylar. The important specification is that the plot must be contained in a rectangle whose exterior dimensions are 22"x16", so that there is a 1" boundary all the way around the 22"x16". This is easier said than done. In order to work out the page setup, I have worked out the plotting parameters on a roll of plain paper, which saves the expensive mylar. By trial and error, I hit upon a page setup that does what I desired. The leading edge and the 2 side edges have exactly 1" wide clear boundary. Now comes the trailing edge: the peculiar quality of the 330 is that, once the plot is finished, the machine advances the media so that, when it comes to a rest, I would like the cutter blade to be positioned to cut and leave a trailing edge of exact 1." I worked that out on the paper roll. Now, my problem: when I load the mylar roll, I get only a 1/2" buffer on the trailing edge, all other things coming out correctly. That is, the machine does not advance the media as far as it did when the paper roll was loaded. I have been careful to select "film" for the mylar and "plain" for the paper. All other things remain the same: same page setup, same plot information, etc. To me, this makes no sense whatsoever. I have tried my level best to control all the factors and introduce only one change, namely, the substitution of the mylar roll for the paper one. I am at my wits end. I would appreciate your assistance. Thank you. Phil Costaggini
Feb 28, 2017 | HP DesignJet 330 InkJet Printer
HP DesignJet 330 InkJet Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
