Question about Bosch Washing Machines
How to disconnect to enable replacement machine
  • 909 Answers
3 things. 1)switch water supply off and dissconnect pipe off the machine. You will be using that pipe again. 2)remove draim pipe from drain. 3)unplug power.
New one comes with locking bolts which are used for transporting. They must be removed once unit is in the washing room. Never run machine with them still connected. when in position, put water pipe back on, then the drain pipe then apply the power.
Posted on Sep 24, 2009
HP error code 363, what does this mean?
I went online and found the HP8600 user manual and this is their solution to the error code 363 that you reported, which I copied off their site. Hope this works for you:
  • Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
    beaac3qsmgaaaaaelftksuqmcc
    NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
Solutions
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
May 27, 2014 | HP LaserJet 3050 All-In-One Printer
Fax failure error 405
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required or on a long extension and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • If the line is ADSL broadband (Internet) enabled ensure that there is sufficient filtering into the telephone socket. You existing filter may need replacing.
Sep 15, 2011 | HP OfficeJet 4315 All-In-One InkJet...
Sigmatel s18 alawys handsfree mode sir, plz help
i get disconnected every 5 mins when im on online games... Microsoft Windows [Version 6.1.7600] Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\vaio>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : vaio-VAIO Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : 00-26-43-FA-BD-FC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Marvell Yukon 88E8057 PCI-E Gigabit Ether net Controller Physical Address. . . . . . . . . : 00-24-BE-84-48-99 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN Physical Address. . . . . . . . . : 00-24-D6-3C-A4-1A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::2565:e8a3:5e8f:4e8d%11(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.103(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Monday, May 09, 2011 6:54:42 AM Lease Expires . . . . . . . . . . : Tuesday, May 10, 2011 6:54:41 PM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 184558806 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-9C-59-56-00-24-BE-84-48-99
DNS Servers . . . . . . . . . . . : 192.168.0.1 NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 17:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Tunnel adapter isatap.{07E2F4DD-B9BA-4164-9865-1833EC48EA69}:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:8bb:234c:8f31:410a(Prefe rred) Link-local IPv6 Address . . . . . : fe80::8bb:234c:8f31:410a%15(Preferred) Default Gateway . . . . . . . . . : :: NetBIOS over Tcpip. . . . . . . . : Disabled
May 09, 2011 | Computers & Internet
Sound icon shows a small red x and there is no sound although the video is fine. I have never had this problem before, but I don't use YouTube a lot.
Make sure , you have not mute your sound..Click on red X & try to increase the volume of you machine or on the you tube....
Thanks for choosing Fixya.........
Sandeep
Mar 19, 2011 | Computers & Internet
How do I reset lockout feature?
the only reset there is is to disconnect the power for 5 minutes, if that doesn't correct it then the machine is defective
May 25, 2010 | Kenmore Elite HE4 Electric Dryer
I replaced it and the car will start
Try what we call a hard boot to the pcm. Disconnect the positive cable wire from the battery, enable the anti-thift system and than connect the positve cable back to the battery and see if that works
Apr 26, 2009 | Chevrolet Malibu Cars & Trucks
Wireless device is disconnected and disabled. Can't connected to internet. In another room, there is an AT&T Gateway that allows my laptop to connect from up to 150 ft away. But my niece brought her...
first of all you need to check after connecting it with the network cable are you getting any ip address.
if its showing you media disconnected then you need to check the cables.you can also try to reinstall the NIC card from device maneger.you can also try to enable the device just right click on your network connection and click on enable.
Apr 02, 2009 | E-Machines Computers & Internet
Disconnection of computor to wirless modem when fax / phone hand held is activated
try to change the option for enabling the auto line transfer to handphone on pickup
(if the disconnection occurs during ur data transfer/FAX/voice call, this is usual..dont worry)
bye
Was my tip helpful?
Feb 11, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
