Question about Epson Stylus Photo 1290 InkJet Printer
Black ink on sides of paper. They look like roller marks? Can I clean the printer or does it need a new black ink cartridge?
    Sniper:
  • 70 Answers
As you said it looks like a roller marks, so just clean the roller first.
Posted on Sep 24, 2009
SOURCE: Printer is leaving black ink marks all over paper.
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
Posted on Oct 08, 2007
IB4G2008
  • 3587 Answers
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Posted on Feb 28, 2008
rockfixya
  • 679 Answers
SOURCE: Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: Black roller marks on right side of paper
Sounds like you have a bad fuser assembly if the drum unit didn't solve the probelm.
Posted on Mar 16, 2009
SOURCE: dell 926 photo printer will not print black ink.
I'm am having the exact same problem with a new Dell 926!
Posted on Feb 16, 2010
How do I get rid of black marks are appearing on my printing with my Lexmark C544
Are the black marks in the same place on every print. If so, then it could be that the paper feed rollers have got black ink on them, this will need to be checked and if this is the case then it's a simple case of just cleaning them, some kitchen roll and mild soapy water and drying.
Then test the print quality.
Has then been happening since you last changed the black print cartridge. If so it could be a badly fitted cartridge or damaged cartridge. To check to see if the cartridge is fitted badly, take the cartridge out and try re-fitting it carefully, whilst you have it out of the printer you should check to see if there is any ink leakage from the cartridge, is there is then it's time to get a replacement.
Hope this helps, good luck.
May 22, 2014 | Office Equipment & Supplies
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
When printing on my Canon PixMA iP4500 printer I get a 3/16'' black stripe down the back of the page which ruins the page and uses excessive ink.
Thank-you for clarification.
Because the line or marks are on the back of the paper I suspect that it may be a faulty ink cartridge. Your first step would be to press te paper feed button on the printer; it should send a clean page through. If the markings are there then you must inspect the printer for any hidden pools of ink. clean all the areas with methyl hydrate, including rollers. Replace the black cartridge with a new one. I suspect that your current cartridge is one that you have had refilled. A refill is very economical but sometimes they damage the fill port seal allowing air pressure to push the ink out causing a pool of ink. Because the ark is allways at the RHS, were the printer jet assembly parks itself I suspectyou will find the pool of ink at that side. It would eventually drip itself dry. Buy a new cartidge.
Dec 01, 2009 | Computers & Internet
Cannon Pixma MP500- I get a solid black line on the reverse side of a printed page. Went through all the cleaning procedures and new cartridge, no change.
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Jun 23, 2009 | Canon Office Equipment & Supplies
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Have hp descjet 3900 series printer. the printouts started appear with smudging black marks on the paper. how to solve the problem?
REPLACE A NEW CARTRIDGE AND VERYFY THAT THIS IS REPEATING . IF YES CHECK WEATHER INK HAD LEAKED OUT FROM THE SERVICE STATION.CLEAN AND WASH OUT PRINTER SERVICE STATION AND PAPER FEED ROLLER .
May 04, 2008 | Office Equipment & Supplies
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Jan 23, 2008 | Konica Minolta magicolor 2400 Laser...
Epson Stylus Photo 1290 InkJet Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
