Question about Pioneer TS-W3004SPL Car Subwoofer
Mazda 626 Philips logic control radio turns itself off.
I have a Mazda 626 fitted with a Philips radio CE-3434TY1. It has logic control switching which I believe is faulty as it turns itself off at irregular intervals from a few seconds to an hour or so. I have searched for a dry solder joint and resoldered over 100 without effect. I now suspect it is the logic control switch losing its latch. Can a replacement board be obtained from anywhere?
  • 6 Answers
SOURCE: red led on power supply board comes on after I turn power on.
I have the service manual for the set.
email me and we'll work something out.
las dot trampas at gmail dot com
Posted on Oct 07, 2008
SOURCE: Pioneer elite pro 100
My set is doing the same thing again. The last time I fixed this (4 years ago) it was a capacitor gone bad in the power supply for the 24v standby circuit. (C166)
The service manuals can be ordered directly from Pioneer Part Number ARP3014 for Pro-100 model.
Posted on Dec 21, 2008
  • 50 Answers
SOURCE: Purchased my son a second
Unless changed cby the owner it should be the last 4 digits of the VIN number which can be read from the label on the driver's door panel. If it has been changed, I'm afraid there is no way to retrieve it unless you can contact the previous owner.
Posted on Sep 22, 2009
  • 3 Answers
SOURCE: Pioneer SD-643HD5 - tv would turn on and then 1
Just wondering if you got this problem fixed by replacing ICs - I got the similar problem with my TV
Posted on Jan 03, 2011
caroldon
  • 17129 Answers
SOURCE: thank you ur answer but still not clear my mind
I dont have the intial fault condition mentioned but I think what is required is to check the SMPS- which is the switch mode power suppy. Now this can be checked ONLY if you are able to handle a mutlimeter to check the voltages on the board.
Also when I mentioned DRY solder it is solder that dries and loses contact after the joint has heated several times.
For soldering tips please check on:
http://www.solder.net/technical/tips.asp
http://www.kpsec.freeuk.com/solder.htm
Posted on Oct 22, 2011
1997 mazda 626 cruise control not working
Check the 20A STOP FUSE and 10A METER FUSE in the joint box but also there may be no speed sensor input that signals the cruise control to engage.
Sep 09, 2014 | 1997 Mazda 626
Mazda 2200 if the dash lights dont light at all when u turn the key to acc. does that mean a bad switch if all otther lights work and the battery is fine
Not sure I follow you.
Do the warning lights come on when the key switch is in the on position ? ?
And are you saying the engine will not crank ?
On most cars the only thing that is powered in accessory is the radio.
Feb 21, 2013 | 1983 Mazda 626
Where is the backup switch located on a 1998 mazda 626
It is part of the range control switch on the oustside of the transmission case where the transmission cable hooks up, it fits over the post that sticks out of the ******.. See picture below, part is about $100.00
Oct 05, 2012 | 1998 Mazda 626
88 Mazda 626 won't turn over
try the fusable link near tyhe battery
Aug 15, 2009 | 1988 Mazda 626 Turbo
1999 Mazda 626 no rear lights!
checked the fuse of the park light.
Apr 15, 2009 | 1999 Mazda 626
91 mazda 626 erractic idle surge when engine is cold
My '91 626 did the same thing. I tested the throttle position sensor, and it was good so that wasn't it. The other likely culprit is the Idle Speed Control valve, or Idle Air Control valve, which is a $500 part new (more than I paid for the whole car). I pulled one off a 626 at the salvage yard and got it for 3 bucks, put it on (it's an easy DIY, just 4 philips screws holding it to the intake manifold), however I can't be sure that solved the problem, since I haven't run the car much since then. It would seem the most likely cause, tho, and a cheap fix if you go used. Other possibilities: O2 sensor or Mass Air Flow sensor?
Feb 16, 2009 | 1991 Mazda 626
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: N/A
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
Aug 03, 2008 | 1990 Mazda 626
Purchased my son a second hand Mazda 626. Its fitted with a Philips Logic Control radio Philips No CW077A or Fujitsu Ten No CE-3434TY1. I obtained all the owners manuals with the vehicle but unfortunately...
May 03, 2008 | Car Audio & Video
Pioneer TS-W3004SPL Car Subwoofer Logo
117 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
