Question about Philips 42FD9954 42 in. Plasma HDTV
Philips 42FD9954/17 Power Problem, will not turn on.
The DC power relay will not energize when the on button is pushed. I have two monitors that act this way.
Have made some ac and dc voltage checks with the units off and compared them with a good monitor in the off position and they look good. Have ordered a service manual but would like to know if this is a common problem with this model. If so, what component should I look at ?
  • 5 more comments
  • Chem58 Dec 22, 2007
    The TV will comes up with the red flashing LED indicating no signal. The repair shop suggest power supply problem but phillips will not help. Probably a very simple solution.
  • Bob Browning Dec 22, 2007
    Hello Guest, Thanks for the info on the voltages. I am tracing the complete power supply circuit. What a job, it has many many protection circuits that will shut down the power supply or at least the relays will open. Will let you know when I find the problem.
  • Anonymous Jan 02, 2008
    i just got one of those sets it has the relay blinking problem ,,If i could get the power supply schematics may be i could diagnose it
    if any body could make it avalaible please contatme at carcalder@juno.com
    regards
  • Bob Browning Jan 03, 2008
    Response to Dec 19,07 ....power supply voltages. I measured the voltages on my good unit and they are as follows: (Standby) 25 volts reads 13 volts, 9 volts reads 5.4 volts, 5 volts reads 4.8 volts, the 3.3 volts reads 3.4 volts. With the unit "on", they are 25 v reads 20v, 9v reads 9v, 5v reads 5v, 3.3v reads 3.3v. remember this is with a good working unit, be sure you measure the voltages with the corrrect ground, the unit has a flooting "Hot" ground. My bad unit measures the same voltages in "Standby" mode as the good unit, I have two bad units like this.
    I believe the problem is the TNY256P power switcher. I tryed to order one on the internet and out of 5 venders I found only one who has it and it is on backorder! The company is www.mouser.com , $ 1.05 each. Regards....I AM I
  • Bob Browning May 06, 2008
    Philips Plasma Tv's have some bad capacitors, try replacing 2540 (100ufd @ 25v) and 2408 (4.7 ufd @ 50v) on the power supply board.
  • cheb Jun 04, 2008
    Hi the problem i have is when turning on to standby, light just flashes & a clicking can be heard, I have removed the back cover & led on main board flashes & clicking is coming from a box just above led [possibly a relay], I have tapped relay whilst unit is trying to turn on & unit started working ok. After about 30 min. i turned it off again fault returned, could it be the relay & where can i get one please. Thans in advance Pete.
  • mmusa1970 Aug 20, 2008
    NO POWER,JUST THE RED LED IS ON,
I repaired this model TV for a friend. The red standby LED would take about a minute to come on, and most of the time the TV wouldn't turn on even after it, and the relays would engage/disengage rapidly when it did try to turn on. After reading about the capacitor problems, but not finding any obvious physical issues with them (and not having a way to readily test capacitances) I went ahead and replaced all the Rubycon branded caps on the power board. This solved the problems - the red standby LED comes on immediately and the TV turns on like normal with a single click engagement of the relays. It seems the problem is just the low quality/defective/bad run of capacitors. I spent about $40 on capacitors at a local electronics supplier, but probably could have spent half of that if I hadn't wanted them right away and ordered online.
Posted on Nov 01, 2009
  • victor
    victor Mar 07, 2014
    the Rubycon branded caps on the power board. what it mean ?
Hello: I'm having the same problem, Your voltages can't be good . the issue is on the standby power supply, that is the TYN256 IC, but that IC is not the problem, something else cause the voltages go all wrong, where it's suppose to have 24V i read 12V, on the 9V, reads 6.8V , the 5V reads 3.8 , the 3.3 seems to be good, the problem is you need 9V to energize the relays, I've checked for shorts and nothing, all components look good, this IS a common problem, and I'm pretty sure it's cheap to repair , just nobody seems to have the right clue that what's the faulty component.
Posted on Dec 19, 2007
Compressor clutch engages when I jump the relay, and I already bought a new relay. What could be preventing the compressor from recording power.
The compressor from recording power ? First off what make , model an year vehicle ? When you jump the pins where the relay plugs into , By the way that should be pin's 30 & 87 .look on the bottom of the relay .Besides 30 & 87 you will also see pin's 85 & 86 ! 85 ,86 are the control side . When you push the A/C button on the control head ,depending on make , model an year vehicle , the control head sends a turn on request to the BCM - body control module or right to the PCM - engine computer .The PCM will then energize the compressor clutch relay ! Is there control from PCM ? Before the the relay will be energized the PCM looks for a signal from high an low pressure cut out switches . Your best bet would be to take your vehicle to a qualified repair shop .
Aug 05, 2016 | Cars & Trucks
2007 cobalt horn relay location
The relay is located in the under hood fuse / relay box . Marked HORN PCB relay , If you change it out an horn still doesn't work ,you can test to see what is missing right at the relay . Two of the pins at the relay socket should have battery + , one should be open an the other should show ground 0 ohm's . If you look on the side of the relay there is a diagram of the pins. 30, is Battery +, 87 goes to the horn . When you push the horn button on the steering wheel it causes the relay coil to energize closing the contacts in the relay sending power from pin 30 to pin 87 down to the horn turning it on ! Pins 85 an 86 are the control side , one should have battery + an other should be open , till someone pushes the horn button . You can test for power with volt meter an test with ohm meter for ground on the one , an a open on the other one, an have someone push the horn button an it should change to 0 ohm's .
Mar 01, 2015 | 2007 Chevrolet Chevrolet Cobalt LS
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
I have a reebok crosswalk rt 5.0 treadmill. I can calibrate the incline and it goes up and down. however when you press the button to raise the incline the incline number will change but the machine does...
Step 1:
see this details and proceed according. God bless you
LED.
Step 2:
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
LED.
operating properly.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Jan 07, 2013 | Reebok Exercise & Fitness
My new visions t9550 treadmill will not calibrate. it completes the speed calibration but treadmill will not elivate therefor fails calibration. what do i do?
Step 1:
follow this steps for troubleshooting and fix it. God bless you
LED.
Step 2:
LED.
operating properly.
Step 3:
Try this again. and fix it.b) LUBE the gear motor, shaft and turn the POT a little and see if the motor get RPM.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in).
Jan 07, 2013 | Vision Fitness T9550 Folding Treadmill
Initial calibration keeps failing. the treadmill will not elivate
Step 1:
please see this test and fix it. God bless you
Step 2:
LED.
LED.
operating properly.
Step 3:
please lube the elevation motor, shaft, and gear, and adjust the POT for RPM, and see what happen. see the diagram + block diagram attached for troubleshooting and fix it.
God bless you
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I have an 1989 jeep comanche. It had an ignition switch bypass. I took it off and replaced the switch and the relay. If i touch the positive battery cable to the green starter wire on the relay it...
on the relay there will be a small wire that gets power when you turn the key to the start position
find that wire and connect it to the small terminal of the starter solenoid
then if you get it right , when you turn the key to start, power will get to the starter solenoid , energize the solenoid and the starter will engage
Jun 03, 2017 | 1989 Jeep Comanche
Push power button to turn on tv, two seconds later, before the picture arrives, power goes back off
holding circuit for the power on relay not working. suspect bad micro relay failed.
Sep 20, 2009 | Philips 30PW8420 TV
Philips 42FD9954 42 in. Plasma HDTV Logo
3,193 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
