Question about Jenn-Air JES8850 Electric Kitchen Range
Jenn air cook top with oven Model D146-C
The electric element grill side of the range just stopped heating up. The fan also stopped working. All this happened while I was cooking steaks. I was using the oven and the one other burner as well.
  • 2651 Answers
SOURCE: jenn air range top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Posted on Mar 15, 2008
SOURCE: Oven shuts off
replace oven temp.sensor
Posted on Nov 20, 2008
SOURCE: Jenn Aire JGS9900BDS
it is probably the control board. Mine did this and they changed the control board.
Posted on Dec 13, 2008
  • 309 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
SOURCE: Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Posted on Nov 27, 2009
SOURCE: Jenn-Air model svd48600. Gas stove top, electric
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Posted on Mar 04, 2010
0 characters
1 Points
Why does my oven cook so unevenly? In the top area, the back cooks way faster than the front. In the bottom, the right cooks way faster than the left.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Jan 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
The clean cycle requires both heating elements to run at the same time.
Since your oven is a 220volt, each heating element will require their own 110v source to heat the oven. This means that the stovetop elements will need to be disabled to prevent the breaker from tripping since the cleaning cycle requires a lot of electricity to do it's job.
There is not enough wattage left over to both clean and cook, this is why cleaning is recommend during a time in which you will not be using your oven.
Nov 07, 2010 | Jenn-Air JES9860 Electric Kitchen Range
Heating element in my electric Jenn-air oven
This is one of the most simple repairs you can make on your range. And it's so affordable that you shouldn't think about replacing it!!
Just contact us at:
with your complete model number and we provide part removal/installation instructions for you when you purchase your parts through us.
We want to get you cooking again soon, so call us asap.
We look forward to working with you! Thanks, Ella
Jan 07, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Selector to Clean
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Grill Element
I believe this is working as designed! The downdraft fan always turns on when I run my own grill!
Oct 20, 2008 | Jenn-Air JES9860 Electric Kitchen Range
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Dec 19, 2007 | Tecnik TKC1285 Dual Fuel (Electric and...
Stopping cold air
Depending on where it is vented you probably wont be able to stop the air. Take the grill out and see if there is a door flap that is supposed to close when the fan is off. If not your out of luck.
Nov 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JES8850 Electric Kitchen Range Logo
465 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
