Home | Fuji | FinePix A360 Digital Camera | When i turn on my cam...
Fuji FinePix A360 Digital Camera
Problem for Fuji FinePix A360 Digital Camera
When i turn on my camera it will not extend or let me set the men
By audreya_good on Sep 24, 2009
i just put new batteries in this camera and i cannot set the date and it will not take a picture.
Same Problem
Sep 24, 2009
-   I just changed the battery and my camera will not do anything. It will not come on at all. -   hubbardpj758
Solution #1
posted on Sep 24, 2009
Somewhat Helpful)
colin614
Rank: Apprentice
Rating: 75%, 1 votes
Check batery type suitble for your camera, also ensure correctly installed(+ -) Check contacts are clean
Was this helpful?
Yes
No
Solution #2
posted on Oct 01, 2009
Not Rated)
Gary Malcont
Rank: Guide
Rating: 100%, 1 votes
Camera will not power up with new batteries installed.First make sure the batteries are fully charged and installed properly.Looking at my Fuji A360 (takes 2 AA batteries) i see with the compartment open and batteries removed a plus + sign and a minus sign - located just inside the compartment in front of where you insert the memory card.I had to put my glasses on to see but its there.Ok,another problem could be corrosion on the battery contacts-see post for removing corrosion.All right now-could be the metal contacts are pushed down and need to be pried back up so the battery makes better contact.You'll need to fashion a piece of stiff wire(but not too big a diameter piece) into a hook and keep prying or hooking the metal contact till it bends upward (i had to put my glasses on and use a magnifying glass along with a brite light to see what i was doing).Additional tip-according to the manual use AA alkaline batteries or AA size Ni-MH rechargable batteries.Well unless you have an endless supply of regular AA batteries or you like running to the store to buy new ones,get rechargable batteries!I just charged my "old" rechargable batteries yesterday and when i turned on my camera they were already dead.I know the batteries were my old batteries because i taped a lable to the batteries to keep from mixing them up with the new ones i just bought (i keep extras so i always have charged batteries).Old rechargable batteries lose their charge faster if left in camera but are fine to use rite outa the charger,just make sure you have a new set charged up if your taking alot of pictures or won't be where you can plug the charger in (i take my charger along with me when i go somewhere-keep in camera case).Also i buy different brand of batteries so i can tell the batteries apart (which ones i've charged) if youre like me and have several devices that take AA batteries or lable them.One more quick tip-i see my brand of batteries say-Nickel Metal Hydride 2000 mah.Hope this helps someone,Gary Malcontent
Was this helpful?
Yes
No
Popular Solutions for Fuji FinePix A360 Digital
Questions and Unsolved Problems for Fuji FinePix A360 Digital
Do you recommend Fuji FinePix A360 Digital Camera?
Answer
Answer
When I turn on my camera, the lens does not extend, even after putting in new batteries. The camera... (More)
Answer
on viewing screen i have lines going across -help !!Need the camera for a family party soon so a... (More)
Answer
when i turn it on it doesnt extend. but if i push the zoom button it extends but the picture is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fuji FinePix A360 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
