Question about Keurig Ultra B50 1-Cup Coffee Maker
Coffee grounds in keurig
I am getting more coffee grounds in my coffee cup
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Posted on May 19, 2009
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Posted on Jun 14, 2009
  • 3600 Answers
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
Posted on Aug 26, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
  • 211 Answers
SOURCE: Coffee grounds in cup w/ Keurig 60
This is a problem with the k-cups themselves. Each K-cup has a coffee filter type media in the top and bottom of each k-cup. It sounds like you may have purchased a batch of k-cups with a defective bottom filter. Just to be sure, run your Keurig with no k-cup in it at all and see if it flushes clear hot water. Since your holder may have remaining grounds from the defective k-cups, you may have to do this several times. Once this is done, you can confirm it is working with another brand or batch of k-cups. The only way the brewer itself could be the cause is if the needle in the bottom of the k-cup holder has somehow become dislodged and is piercing the filter in addition to the k-cup bottom.
I hope this helps. Good luck!
Posted on Mar 13, 2010
The single cup server runs over and grounds go everywhere.
Bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 30, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
My k cups are shooting coffee grounds everywhere!
heatman101
Aug 26, 2011 | Keurig B60 Coffee Maker
Kcup is dumping all the grounds into the machine and coffee cup
heatman101
Aug 15, 2011 | Keurig B60 Coffee Maker
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
When i brew a cup of coffee with my Keurig coffee maker there is a lot of coffee grounds that do not filter. Its like drinking dirt. How do I fix my issue?
heatman101
Nov 08, 2010 | Keurig Elite B40 Coffee Maker
Keurig Ultra B50 1-Cup Coffee Maker Logo
1,208 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
