Question about RCA P52937 52" Rear Projection Television
Bad power botton,volume,channel,and menu botton
I can't turn on my t.v.unless with the power button,it will turn on with the volume button and the menu butoon wont work,the channel buttons control the menu. When I push the channel button to go to a certian function it will automaticley go to the function.The controller doesn'nt work as well.Can you please tell me what the problem is.Some one said it could be that the Eeprom has failed and to unplug the t.v. for 15min.,but that did'nt work.
Thank You,James
  • jgfran Dec 16, 2007
    Is it something I can do myself?
    Is this something I can do myself or do I need a repairman?I have a little experience in electronics.
Thank you,but I already fixed it,and it was the buttons and the part is no loger avilable from RCA so I had to replace all the buttons and it only costed $20.00.
Posted on Mar 07, 2008
  • 61 Answers
The buttons in front panel of the tv are bad,part number for these are 268854
Posted on Mar 05, 2008
Forgot password Samsung Galaxy tab 2 7.0
All personal data will be lost!
Turn off hold these 3 keys in this order volume up then home button and last power button. Wait until samsung logo appears and let go power button. When you got a menu with volume keys select wipe user data confirm selection with power botton. Last step it will ask to cofirm again select "Yes" and confirm with pwer button again. Hope this help you!
Feb 17, 2015 | Samsung Galaxy Tab 2 7.0
Cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Aug 29, 2012 | Samsung Televison & Video
How do i do a factory reset on my motorola atrix 4g
power off. Hold the volume down botton while powering up. Continue to hold the volume button until the "fastboot menu" comes up. Volume down til you get to "android recovery". Hit the volume up botton to select. Wait for a creen to come up with a triangle with an ! inside. Tap the screen a menu will pop up. go to opt4 and select "factory reset.
Jul 31, 2012 | Motorola Mobility ATRIX 4G (16 GB)...
My four year old was messing witht he bottons on the front of my Apex AT2702 television set, and not all it shows is a blue screen with a key symbol in the bottom left hand corner.
Hi
There are 7 buttons with its front panel including power ON/OFF switch button.They are; From left to right:- Video, Menu, Volume(-ve), Volume(+ve), Channel(-ve) and Channel(+ve). If these buttons are not there, it will be difficult to operate this set without a remote control. If you haven't the remote contro with you now, buy one universal remote control. The universal remote control suited for this set is COMCAST ON DEMAND CUSTOM-3 UNIVERSAL REMOTE control. The setup codes are:-
0748, 0765, 0767
OK.
Jul 11, 2011 | Apex Digital Televison & Video
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Remote will not change the volume
Is the front funtion button works in the TV the it could be a bad remote controller(the button switch inside) :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Sanyo
Go into the setup menu and turn off closed captioning. The black box is a text box for CC. Some stations are sending the signal which triggers the box, but are not actually sending any text.
Mar 30, 2008 | Sanyo DS27930 27" TV
Bad botton panel
jgfran,
You can try powering the unit off, unplugging it for 15 minutes and see if controls return.. It's a long shot, because what you're describing is usually the Eeprom failure, RCA p/n# 241275...
The Eeprom is located at U13102 on the signal board..
Bill
Dec 16, 2007 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
