Question about Garden
My cub-cadetrzt50 mower makes a loud noies when I push or pull the control handles.
  • 148 Answers
This model is notorius for this symptom. Take it to a reputable shop.
Preferably a SERVICING INDEPENDANT DEALERSHIP as they have access to any upgrades or service bulletins for your model.
Find your nearest USA servicing dealership here.
Hope this helps!
Posted on Sep 28, 2009
Bolt broke off of adapter and blade. I replaced bolt and it broke again. So i replaced the bolt and adapter and now making a loud knocking sound this is on my cub cadet walk behind sc500z
Hi Diana:
I'd suggest that you pull the spark plug lead so it does not accidently start, and then try this.
Place the mower at a height where you can easily see under it. I use the tailgate of my pickup trucl.
If you put the handle inside the bed of the truck you can put a weight on the handle so the deck is tipped up. With the spark plug disconnected (or even removed) rotate the blade. Chances are that the knocking sound will be from the blade hitting the deck. It is possible that the bolts keep breaking because the blade is not seating properly.
I'm guessing that once you can see under the mower you will find the problem.
Aug 11, 2016 | Cub Cadet Garden
Why do I have to push so ******* the handle to make it go forward?
If this is a self powered mower, you probably need to make an adjustment. (All self-powered mowers need an occasional adjustment). Check your owners manual for the procedure on your mower, they vary by brand and model).
May 16, 2016 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
May 21, 2015 | Cub Cadet Garden
Cub cadet zero turn will not start. Mower cannot be pushed or pulled
There usually is a release on the rear of the machine for pushing ,mine looks like a piece of chain on the right rear. Pulls out and lets the hydraulics freewheel
Mar 24, 2015 | Cub Cadet Garden
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
