Question about Cell Phones
Torque settings for head mains and big end studs for a 5L 3Litre diesel 98 hilux
Can you please help with torque settings, for Nissan NP 200 1.5 dci diesel
there're manuals at www.reliable-store.com that cover everything from wiring diagrams, electrical
diag, fault/error codes, troubleshooting, service/repair/operation/maintenance info, PCV, etc.
that'll be all you need, without doubt.
Apr 09, 2018 | Nissan Cars & Trucks
Torque settings on a yaris 1.3 16v big ends,mains,flywheel,cylinderhead
Toyota Yaris Main and Big end Torque settings:
Tighten the main and big end bolts in sequential order and in two steps.
Main bearings. Stage 1.
22 ft lbs.
Stage 2.
44 ft lbs
Big end bearings.
Stage 1.
11 ft lbs.
Then Rotate bolt head a further by 90 degrees
Head bolt torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
Flywheel spec:
65 ft lbs
Jul 15, 2016 | 2007 Toyota Yaris
2005 TOYOTA HILUX KUN25R DIESEL ENGINE TORQUE SPECIFICATIONS
Hey
As i know you face a lot of problem.Due to this I give you one mail address it really help full for you.Please visit it.
May 03, 2016 | Toyota Cars & Trucks
I need to kno the cylender head torque specs for a 2.3i vw microbus five cylender
The Audi 5 cylinder engine (Engine code AFU) was mainly produced in South Africa and was called a Microbus. The engine capacity was 2309cc. The Microbus 2.3i T3 was produced from 1992-2002.
According to Mead & McGrouther - Data Digest the torque settings for the cylinder head bolts are as follows: 40Nm + 60Nm + 90'degree turn + 90' degree turn. The cylinder head bolts has to be replaced with brand new ones.
The Main Bearings: 65Nm. The Big Ends: 30Nm + 90 degree turn.
The OHC Bearing Caps: 20Nm.
Flywheel Bolts Manual transmission: 60Nm + 90 degree turn.
Jul 28, 2014 | Cars & Trucks
Need torque settings for mazda xa 3.0l diesel 4 cyl
con rod bolt tension is 55-60ft/lbs
crank shaft main bearings is 80-85 ft/lbs
fly wheel bolts95-100 ft/lbs
crank shaft pulley nut 94-123 ft/lb
head studs tension 80-95 ft/lbs working in a spiral direction from no 1 stud directly in the centre of the head. Pull down in 10ft/lb increment starting at 20 ft/lbs
valve clearance is .010" both valves cold but after warming engine and re-tensioning the head studs re set valves to .012 both valves
injector retaining nuts tension12-17 ft/lbs
Dec 25, 2013 | Saab 9 Cars & Trucks
Help with torque setting for mazda b2500 wl diesel engine
What is de torque for wl 2500 mazda main bering. Thanks
Mar 25, 2013 | Cars & Trucks
HI HILUX SURF WITH 2LT DIESEL ENGINE CAN I GET CORRECT TORQE FOR. 1-TORQE FOR HEAD BOLT? 2-TORQE FOR CON ROD BEARING BOLT? 3-TORQE FOR MAIN BEARING BOLT?
Torque Settings Mains = 108NM
Big Ends = 54NM + 90° +90°
Flywheel = 122.5NM
Cylinder Head = 78 NM + 90° + 90°
Valve Settings
Exhaust = 0.40 mm - 0.50 mm
Intake = 0.20 - 0.3 0mm
Jun 30, 2011 | Toyota 4Runner Cars & Trucks
Cell Phones Logo
149 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
