Question about Sharp R-1460 Microwave Oven
Our oven started coming on when the door was shut. It is not cooking but the light and the fan come on. Nothing makes it stop except opening the door. I unplugged it for awhile, but that didn't help either. We bought it in 1996. What do you think I should do? Is it worth fixing?
  • Anonymous Mar 25, 2014
    during cooking the fan comes on spontaneously and then won't turn off when trying t turn off. Have to unplug it. After being plugged in again after awhile it works normally for a few days then does it again. Help!
I have the same problem.
I found that by removing the control panel, then moving the small red-buttoned switches around the door open switch seemed to solve the problem.
We felt the problem was a mechanical problem because closing the door very gently permitted normal operation.
Posted on Oct 03, 2009
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
When door is shut some type of internal fan kicks on...
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Mar 09, 2013 | Frigidaire FMV157GM Microwave Oven
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Cooking doesnt start
Microwave?
Generic advice follows.
Do you open the door while the machine is cooking? Do it a lot? For a long time (months)? Check your door safety interlock switches. The microswitches can not stand that type of abuse. I have personal knowledge on this. I try not to open the door until it stops, but it is hard usually to do that!!!
If you need more help, let me know.
a
Sep 21, 2009 | Frigidaire FMV156DC Microwave Oven
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
Sharp r96st stops at 1 sec and halts whilst preheating oven
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
Sharp 1611
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
Oct 13, 2007 | Sharp R-1610 Microwave Oven
Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Dec 21, 2006 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
156 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
