Question about Garden
I have a 61inch husq. the belt will not stay tight
I have a 61inch husqvarna. zero turn. The deck belt will not stay tight on the pullys. The belt is new. What do i do?
  • 718 Answers
First make sure you have the correct size belt, compare with old one. If they are the same then you have the belt routed the wrong way, you are most likely missing the tension pulley in your current routing of the belt. Usually there is a diagram either on the deck of the machine or in the owners manual.
Posted on Sep 26, 2009
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
Model rz4623 zero turn deck belt is jumping a lot
see if belt has burn spots in it that will cause it to jump excessively
Sep 16, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvarna 48 in zero turn deck belt replacement
drop the deck to it's lowest level and replace the belt. you will have to remove some guards on the deck for access to the belt.
May 11, 2014 | Husqvarna Zero Turn Mower Z5426
MOWER DECK BELT WON'T STAY ON.
Could be a bad belt,rusty pulleys,misadjusted or missing belt guides,or something bent causing misalignment of pulleys
Jun 17, 2009 | Husqvarna Zero Turn Mower Z5426
The mower deck doesnt stay kicked in
1) check condition of deck drive belt
2) check condition of belt tensioner system located on top of the deck.
tensioner system pivots and also applies brakes on spindles
being worn, it does not give full travel to tension the belt
3) make sure engine mount bolts are tight
4) engine 'Stack Pulley' groove can be worn
5) check idler pulley bearings
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jun 15, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Belt jumped off pullies
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
Apr 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
