Hello my sanyo C20BG2TXN it start without deflexion coil,when i connect it there is a sound (tic tic tic...)on flyback transformer and speaker.
  • rcadembo Sep 24, 2009
    Those capacitors are ceramic or electrolitic.firts time it had a capacitor of 474k/2.2kv it was in chunt i replaced with 2 of 474k/1kv in series and worked for 1 month and had trouble of horizontal transistor then i replace it.Now i can hear sound without coil deflection but it tick only with the coil that is streihgt with Flyback transformer .
  • 5,138 Answers
Ticking sound it telling you TV is in shut down you either have a bad capaciotr in the high voltage circuit or a Bad FBT flyback transfomer if a capacitor is bad look for either a 1uf 100volt cap or 2.2uf 100volt But first resolder all the pinns on the FBT.
Posted on Sep 24, 2009
Ego tv flyback tic tic sound problem how to repair
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jul 15, 2016 | Televison & Video
What is the flyback transformer number of sanyo tv ST-21SE1
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Flyback transformer data is given. Search the site with the keyword "Flyback Transformer". Type in these words in the search box located at the top right of the display window.
Jun 20, 2015 | Sanyo Televison & Video
My set is having a vertical fold over. I can`t see the upper portion of the picture. It has also a vertical retraces and a white horizontal line on it`s center..I replaced bulged electrolytic capacitors...
Hi
Please check the DC supply voltage applied to the IC. If it is higher than the specified voltage, replace the filter electrlolitic capacitor near the rectifier diode. This circuit is generally located near the flyback transformer. If this does not work the vertical deflexion coil on the CRT neck is probably defective.
Sully
Sep 20, 2013 | RCA Televison & Video
Locate flyback transformer t 402 sears lxi 56448060550 sanyo product?
Hello
What do you want to know exactly. It is not clear to understand from your post. Specify it clearly please. Ok.
Nov 30, 2010 | Sanyo Televison & Video
I replace horizontal output transistor with new one but it happens the same short
check yoke coil for open ckt, and and check for 12 v dc supply to vertical circuit, sometimes resistor open that supply dc voltage coming from flyback transformer.
Apr 27, 2010 | Televison & Video
Sanyo DS27880 TV, vertical sweep is gone, sound ok
Check for cold joints on the vertical chip. DS27880 sets use a la7841 typically.
If soldering doesn't fix it, simply replace the vertical as well as the 1ohm 1/2W resistor and
the fast recovery general purpose (nte556 equiv) near the flyback.
Mar 24, 2009 | Sanyo Televison & Video
Sylvania TV - 3 tics
Not economically. The ticking sound is a sure sign of high-voltage shutdown, and is coming from your flyback transformer - the most expensive part in the TV besides the picture tube. Even if it's not the flyback, troubleshooting the high voltage section is usually more than the cost of a new TV.
Dec 30, 2008 | Sylvania 6427TE 27" TV
TV not coming on
try check the horizontal output or flyback transformer..on the pcb board..sometime lizard die stuck below the pcb and tv shock when you switch it on
Dec 08, 2008 | Samsung DLP HL-P5663W 56" TV
Flyback
FLY BACK MEANS WHAT? is it flyback transformer or pulse fron eht to afc ckt. fly back transformer are available according to kit like toshiba sanyo philips
Sep 19, 2007 | Prima C2012 TV
Rca f27442
Check for shorted base-collector junction on horizontal output transistor designator Q14401. Also coil L14401 going to base of transistor needs to be desoldered, scrape ends, resoldered. If horizontal transistor is shorted, real possible flyback transformer bad.
Dec 16, 2006 | RCA F27442 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
