Question about Evesham Computers & Internet
I have removed the motherboard on an evesham 8889 and a small spring with 4 bits of plastic have fallen out. i think it may be the lcd switch which switches the display on/off when the screen is opened/closed. it has 4 legs connected to the motherboard and is connected between the dc power socket and the screw hole on the edge of the motherboard. can i get a replacement switch and what is is its part number? if not, if i can see how it is assembled i may be able to but it back together. Alternatively, I could solder a link in to bypass the switch
  • 351 Answers
SOURCE: Dell Inspiron 1000 Disassembly
Dear RBROWN67,
you can find the service manual for you DELL Inspiron1000 Notebook , from these URLs:
http://support.dell.com/support/edocs/systems/ins1000/en/index.htm
http://repair4laptop.org/disassembly_dell.html
Hope these sites are helpful for you in future also.
Cheerup and Be Happy always
Posted on Mar 14, 2008
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Posted on Mar 26, 2008
cgpatel1948
  • 258 Answers
SOURCE: in reply to acer tm 2300 power socket problem
Sorry mate cannot help you there. Only thing I can say is learn from your mistake and in future liv the soldering iron to EXPERT. Let the pro handle the work. Buy new PC
Posted on Jul 28, 2008
  • 1861 Answers
SOURCE: Replace Tail light assembly
Loosen ther interior plastic to gain access to the 2 hidden nuts. We use an articulated ratchet to get to the bolts, however. Not hard to do.
Posted on Nov 04, 2008
Kazong
  • 152 Answers
SOURCE: PS2 slim, Bad Power switch is there a bypass to turn the unit on ?
Ouch you got good news and bad..
Bad first. Your PS2 will not work without that ........
But The Good news im sure you might know somebody that has a junk ps2 if you can get your hands on it there is your fix... Sadly Sony wont send you one . try turning the cable around and useing the good end.. ill shoot you a vid that might help
Posted on Nov 19, 2008
Will not turn off
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Was this helpful? Yes No 4 people thought this was helpful
Add a comment
    • davjones101
    • 1 minute ago
    Thanks ,very helpful. Let me just add a vital bit of information On removing front assembly, to remove sliding switch and access spring clip under blue button you have to release locking clip (it's like a long sprung piece of plastic) from LH side by just pushing it to the right with a fine screwdriver etc. It's concealed under another piece of plastic. I also removed inward facig lug on shaver body (under slider) as this snags the metal spring when refixed
    Reply
Oct 17, 2010 | Braun Syncro 7526 Electric Shaver
I need to replace the small motherboard fan. Any
Hi friend,
Yes this is easy task,if you wand to change the motherboard fan than firstly remove the power cord in CPU,pull out the side cover of CPU and than you see the motherboard fan in front of you,Two fans available in system one is CPU FAN and another is motherboard FAN,you need to change motherboard fan,this is attached in motherboard with two iron stick,press the both stick through thumb and press the upper,now you remove the older motherboard fan and fix the new one.after fix the new fan press both iron stick and fix it.
plug the power cable and switch on the system.
Thanks,
Jan 16, 2010 | Evesham Axis 64 FX (AXIS64FXMAR04) PC...
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Camera turns on, beeps, turns off.
Same Issue here!!! Must be a Optio thing...
Feb 17, 2008 | Pentax Optio S7 Digital Camera
Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
Jan 24, 2008 | Braun Syncro 7680 Electric Shaver
Braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
GOOD LUCK!!
Nov 28, 2007 | Braun Syncro 7526 Electric Shaver
Switch not working properly
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display1.gif
GOOD LUCK!!
Oct 30, 2007 | Braun Syncro 7526 Electric Shaver
Computers & Internet Logo
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
