Question about Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster
Require replacement wire which triggers the catch when the operating handle is pushed down. Where can I buy it?.
    Brigadier General:
  • 3,006 Answers
Russell Hobbs products are firmly placed at the budget end of the market and many of their products have little or no spares availability as they're often not designed to be repaired.
However, they do supply spares for some models if you're unable to fabricate the part yourself, see web address below:-
http://www.russell-hobbs.com/parts.shtml
I hope that you've found my answer to be useful and ask only that you return the favour by rating my answer.
Posted on Sep 24, 2009
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
How can I buy a replacement door for a 302 dishlex ?
I was looking for the same thing myself for our Dishlex 300 a few months back. Our problem was 1/ the handle wasn\'t releasing the door catch,
also 2/ the micro switch in the catch wasn\'t getting pressed down properly to tell the machine the door was closed, so the dishwasher wouldn\'t start. Both problems were related to the plastic ramp inside the door being worn where the tongue of the catch goes in.
We couldn\'t find one in NZ, so I made a tapered flat piece of wood to push the catch down between the main body and the door whenever we want to open it.
For the switch problem it was a bit harder - I opened up the plastic box at the top front of the machine (with the power off of course) and built up the plastic ramp that triggers the switch, using glue and then a file to shape it after the glue hardened.
I hope this is helpful.
Cheers.
May 26, 2014 | Dishwashers
The throttle trigger will not work on my 235e husqvarna
I'm guessing from the statement that it "will not work to increase speed" that you have been able to successfully start the chainsaw.
I have to look at this with the assumption that you haven't run a chain saw before, so bear with me if some of this is excessively simple.
If the throttle trigger does not move, something is jammed. The handle for the choke should automatically move to the retracted position when you pull on the throttle. If it doesn't, see if the trigger will move after you push the choke handle back in.
If the trigger moves in when you squeeze it but you don't hear any change in the engine sound then it's probable that the throttle wire has disconnected at the carburetor or at the handle.
Is the chain brake off? You need to pull it firmly back toward the upper handle for it to be disengaged. If the handle is forward it will lock the outer portion of the clutch. If you try to accelerate with it locked the engine will bog and not allow the chain to move.
Any of these conditions other than the chain brake will probably require some disassembly. Make sure you're confident that you've correctly reassembled everything if you're going to do it yourself.
Nov 22, 2013 | Husqvarna 16" Chainsaw Chain Saw Bar...
Clean water and solution will not dispense
This is an unusual problem. The most likely reason is that the supports inside the upper handle grip have broken, and when you squeeze the trigger, the rod that opens the reservoir assembly is not pushing open the valve. If you remove the upper tank, and look behind it, you should be able to see the end of the actuating rod sitting on top of a rubber valve assembly. Squeeze the trigger and watch the rod to see if it pushes down on the valve. If it doesn't, the upper handle grip will likely need replacement. If it does push down on the rubber seal, the reservoir assembly has probably failed and may need replacement.
Jun 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Error 010-297 restart printer
Hi belljohnson5,
The code is caused by a small switch under the fuser unit not sensing the fuser unit is in place. The blue plastic locking tab on the left side of the fuser has a small catch on the bottom of the fuser. The catch is supposed to slip thru a space in the steel plate under the fuser unit and secure the fuser in place. As the catch slides forward under the steel plate, it pushes on the trigger of the sensing switch, closing the sensing switch and letting the copier know that the fuser is in place. (there is also a similar locking tab on the right of the fuser but it doesn't trigger a sensor like the left one does) 1) The fuser gets very Hot!! Let cool for 10 minutes after turning off the power and unplugging the copier! 2) Pull the two blue locking tabs forward and remove the fuser unit. Reinsert and push back on the tabs to lock back into place. Sometimes just reinserting the fuser will allow the catch on the locking tab to function correctly and push the trigger on the sensing unit. Turn the copier back on and pray the error code doesn't reappear.. 3) Mine reappeared. Evidently the catch on the fuser unit was still not pushing the trigger forward, causing the copier to surmise that no fuser unit was installed. At this point, you should buy another fuser unit or take your copier to an authorized Dell repair center.
Hope this helps.
Thank you for using FixYa.
May 05, 2010 | Dell 3100cn Laser Printer
How to fold peg perego 2008 Pliko P3
You also have to pull on the middle part by the basket it has like a handle.
Oct 02, 2009 | Peg Perego Pliko P3 Stroller Umbrella
Karcher electric power washer
Dear, cb_scherer,
I can only give you some hints because I do not know the type and model of gun. First if your gun is put together with rivets and not screws, this could not be serviced. In this case you have to buy a new one. Now if you have screws, normaly Torx(T15) or sometimes Philips....you can open the gun to have a look inside. Some guns have an adjustment for correcting the travel of the trigger. This is a simple alen screw. Now if damage has been caused to the pin that is pushed by the trigger, then also a new gun is a must. In my opinion I rarely service guns. Infact the only guns that are serviceable ,..are of industrial machines. As I said, I do not know what type of machine you have and so I do not know the type of gun you have.
My general advice, is to buy a new gun. A gun is not that expensive. And working with a faulty gun not only in time will damage the machine, but it is also not safe!!
Regards,
Fulltech.
May 22, 2009 | Karcher K2.26 Electric Power Washer
Belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
Hoover SteamVac
I'm not sure what your referring too, but Here is how it works. The trigger is snapped into two "rocker retainers" in the handle. when you pull on the trigger, it rocks and pushes on a rod that goes down to another shorter rod and that one pushes on the valve that releases the solution. A common problem was that the "rocker retainers" would break off and the trigger would not push on the first rod so the machine would not release solution. You will have to replace the handle half (called a trigger guard). The trigger itself has two plastic "springs" molded into it. This is all one piece with the trigger and they don't usually break. Also, when you remove and replace the handle, you have to pull the trigger to re-engage the two rods togeather or the machine will constantly spray solution. I hope this helps.
Jan 12, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Russell Hobbs 9206 Classic Coolwall 2-Slice Toaster Logo
454 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
