No inputs to Capstan motor on Pioneer RT909 Tape deck
My tape deck developed intermittent speed control problems and ran significantly slower. The schematics I have from Pioneer on the deck have some errors in the capstan motor power supply areas.
It looks like the capstan motor runs from a pulse generated AC with a variable frequewncy for speed control. While checking this out I accidentally shorted the emitter of Q245 and lost all power to the capstan motor. Q245 pulse driver? shows zero vdc at base and emitter. The Darlington driver Q214 has 0 vdc as well since it's connected to Q245 base. I pulled both transistors. They seem to show normal junction behavior. The voltages at the open circuit points seem unaffected. My scope shows no input pulses going to Q245 of the capstan motor assembly board. I don't have exact matches for the transistors so would probably substitute others for them.
Meanwhile, I reinstalled the original transistors and got no change in results. All the electrolytic caps and current limiting resistors in that portion of the circuit seem OK (no shorts or opens).
Do you think the DC bias to Q245 base and emitter come from Q214 or somewhere else?
  • 4 more comments
  • Gocart1 Jan 25, 2008
    I replaced all of the drive transistors and speed control IC for the capstan motor. The motor won't turn under power. It has two windings, both of which continuity check ok. Is there a simple way to check out this pulse (?) motor. DC bias for the transistor circuits appear in normal range but the scope shows no pulse activity on them.
  • Gocart1 Jan 26, 2008
    If you don't have a schematic of the capstan motor control assy board, use the pin numbers from the main control B Assy RWG-105 to follow this msg. I'll show the connecting pin numbers for the capstan motor board in ( ). All measurements are VDC with the tape drive engaged in fwd mode.
    Pin 40 (8) Q245 E 23.8V
    Sorry my msg got cut off earlier today. Here is the rest of it.
    Pin 40 (8 on Capstan Motor Control Board) =Q245 E 23.8 VDC
    Q245 B 23.3 V
    Q245 C 22.9 V
    Across Capstan Motor winding 1,
    Pin 25 (2) 23.2 V
    Pin 24 (3) 22.9 V
    Pin 28 (1) Q22 C 22.4 V
    Pin 26 (9) Q22 E 0 V
    Pin 44 (4) lo side of Capstan FG winding 4.9 V
    no pin (TP.21) high side of Capstan FG winding 21.8 V
    Pin 28 Q213 C 22.2 V
    Q213 E 22.1 V
    Q213 B 21.2 V
    Pin 28 Q212 C 22.2 V
    Q212 E 22.6 V
    Q212 B 22.8 V
    Pin 25 Q210 C 23.2 V
    Q210 B 22.5 V
    Pin 31 Q210 E 23.0 V
    Pin 24 Q211 C 22.7 V
    Q211 B 23.0 V
    Pin 31 Q211 E 23.0 V
    Q214 C 33.7 V
    Q214 E 25.2 V
    Q214 B 24.1 V
    Q220 C 13.0 V
    Q220 B 13.6 V
    Q220 E 13.8 V
    Q245 C 25.2 V
    Q245 B 24.1 V
    Pin 40 Q245 E 24.1 V
    I installed new transistors for all the above. Most were OEM spec ID. The PNP power transistors were substitutes, all the same type for the flip flops Q210, Q211, Q212, and Q213.
  • Sam Palermo
    Sam Palermo Sep 06, 2012
    There is a 25 V zener diode that people not used to this deck neglect to check. The Q245 power supply regulator needs voltage at its base to give output and there should be some voltage at it collector.If there is still no voltage even at the collector then one of the safety switches might have opened up they are in series.
  • Sam Palermo
    Sam Palermo Sep 07, 2012
    I don't know where you are getting all the drive information but the Capstan motor is a simple DC governed motor with a FG coil that supplies feedback that gets converted from a frequency to a voltage and then compared in a comparator IC. The Q245 I don't see on the schematic due to good old Pdf files. I will have to check my paper schematics. Most Capstan motor problem stem from a lack of 24 volts going into that driver board. The lack of the 24 volts can cause a lot of problem as it supplies relay power for reel motors and other parts. The first thing is to make sure 24 Vdc is going into the card. We can discuss further if you want directly at skywavebe@sbcglobal.net.
  • Sam Palermo
    Now that I have found Q245 in the power supply section, this Q245 is not a pulse driver and if there are pulses at the transistor there are other things wrong. There shopuld be ONLY DC voltage there and if you are familiar with electronics, this transistor is there to provide current limiting based on the drop of the votage across R293. When voltage get to .7 on R293 the transistor shuts down the Q214 drive. The Q 214 transistor is where all decks that have had no movement when they came in to me have been. The Q210, 211, and213, 212 given the control from Q208 just switch the motor polarity around as this is a reversing deck. First get voltage on Emitter of Q214, then that will power the servo board on Pin 8, then deal with the tension arm switches- they routinely open up die to age. They should be replaced as the voltage for the motor goes through them and if they were resistive this was the problem all along. The voltage of E mitter Q214 should not have ripple or any noise it should be DC only.
  • 1,512 Answers
Could be a nasty fix this one. you will have 2 faults. Firstly the original fault, and secondly the man made one. I hate it when that happens. You dont mention what collector voltages you have. Check DC first is the oldest addage for electronics repairs. It is possible that you may have lost power supply to this stage when the short occurred by failure of a resistor somewhere in the supply line. It can be hard to check the junctions of a darlington transistor without replacing it. The transistor you mention is a series regulator that wont be providing pulses, but regulating to 24 volts. Check the Zener diode in the base of it(should have 25 volts here) and 37 volts on the collector. You wont have voltage at the motor but rather a AC drive generated and controlled by the the IC and FG coil and the 4 transistors q210-213 . You may need to get back to me to help fault find the circuit. I got a schematic at http://www.eserviceinfo.com/download.php?fileid=6302 Get back to me here if you can/cant get the 24v reg back up and we'll attack the speed problem:)
Posted on Jan 26, 2008
  • Graeme Ross
    Graeme Ross Jan 27, 2008
    how is the speed control?
    I have some some probable causes for that too if you are interested?
    regards
    Graeme
    Sergeant:
  • 395 Answers
Check for pico fuses on the 12v motor line or protection fuses that look like transistors but infact are fuses. they may have board location numbers like PSxxx, or PRxxx.
Posted on Jan 25, 2008
  • 790 Answers
Simple! just follow the lead Voltage!
Posted on Dec 16, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Dec 16, 2007
    then follow the path! at this time dont use the scope use an ohmmeter tester! like a broken bridge you can not pass your car at the bridge!
CT-W103 play back is to fast
You may have some broken tape wrapped around the capstan. The capstan is the small silver post that rotates when the tape is playing. A rubber roller presses the tape against the capstan. This silver post needs to be just that - silver. If it has any brown tape or goop on it, clean off the tape or goop with a small knife. Then follow up with nail polish remover [acetone]. Don't use alcohol because that will harden the rubber roller over time.
Feb 15, 2016 | Pioneer CT-W103 Single Cassette Deck
I have a Tascam 688 mini studio, its 8 tracks on a cassette tape, I have just replaced the capstan belt and now the tape speed is way too fast even when I'm in variable mode with the speed turned all the...
It is possible the control transistor in the capstan motor has shorted due to age. There is a control in the deck for calibration of speed but then you need equipment and a MXT111 test tape to set the speed. So you may need a new Capstan motor or maybe just an adjustment- hard to say exactly without me looking at it- yes, I still fix them. I have been doing them for about 45 years and I worked at Teac as a Lead Tech in Arlington Heights IL.
Mar 13, 2015 | Tascam Audio Players & Recorders
Reel to reel tape will not play
Gary hi! If the rubbers are okay then the only problem can be a motor that has lost its strength or the power supply of the deck. A common problem is the PAUSE controller not disengaging and then the brakes are on and the capstan roller pressure is not up to specks
Sep 29, 2014 | Audio Players & Recorders
Wish to repair speed control on BIC T-3 cassette deck. Have had several techs try to repair speed control to no avail. Tape speeds up randomly. Alvin & Chipmunks(:
Recorder fan hi! Check the voltage of your motor and then fit a generic motor to it. Check the belts and lubrication of the shafts of the capstan bush a small drop of sewing machine oil works wonders also check the roller geometry is it round and the tyre touching surface is it flat or is it bulged If bulged replace.
Sep 13, 2014 | Audio Players & Recorders
Tape deck(component)SUDDENLY plays tapes slower - wouldn't a faulty belt gradually play tapes slower?
It could be a lose belt but also a motor is decaying or the capstan bearing has no oil in it. Many things can cause this problem.
Feb 10, 2014 | GE Audio Players & Recorders
Cr2406a cassette plays so fast you can't understand words
The speed of the deck is regulated by two things- one is the pinch roller engaging the tape to the capstan shaft. If this is happening, then the capstan belt may have ridden up on the outer edge of the motor pulley OR the capstan motors DC servo control has a shorted transistor in it and that means you need a new motor. I have just obtained some motors for cassette decks that might work in your unit- the only way to get it fixed at this point is to have a Technician work on it. It will not fix itself nor improve.
Aug 20, 2012 | Audio Players & Recorders
Kenwood Dual Cassette deck KX-97CW runs fast
Sometimes this is due to the tape not being pinched between the capstan and the rubber roller.
Make sure there is no slack in the tape when you put it in the deck. See if you can observe the tape going down over the capstan on the correct side.
If this isn't the problem, then the mechanism that engages the capstan roller may not to be working. In most cases, the rubber roller is mounted on the same mechanism that moves the record-play head against the tape. If this mechanism isn't moving, that would cause the problems you describe.
Jan 31, 2008 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette Player
Motor speed needs to be regulated by PWM. Reducing the current (with a resistor) actually lowers the torque - which, with a given load, does result in reduced speed - however, different length tapes (60min vs 90min), as well as different quality, and even current position in the tape, will change the load and hence the speed. You need to regulate the speed via PWM. It's sometimes done on a small board built into the motor, in which case you'd have a round hole into which you could insert an INSULATED screwdriver (tiny flathead wrapped most of the way in electrical tape works). It may be done on the main board, in which case you could find a pot conveniently labeled "motor speed", or perhaps "pulse width" or "pwm" or something to that effect. Find it, mark its current position just in case, and turn it to see if it gets the effect you're after. And there are some tape decks in the world with no speed adjust - they are designed with a specific speed motor and the sizes of the wheels and gears are calculated for that speed. Also there may be a mechanical fault/malfunction causing the speed problem. An initial check and thorough cleaning of the capstan and pinch roller should be done. If there is a buildup of tape oxide or a piece of a broken tape wrapped around the capstan, the tape travel will be too fast (do to the effective increase in capstan shaft diameter). If the pinch roller isn't fully engaging, the tape can be getting pulled onto the takeup spool at a speed faster than the capstan control. A different source of trouble might be a slip clutch (possibly an idler/clutch assembly)which is binding, or otherwise not functioning the way it should. Another type of motor doesn't have it's speed controlled by an internal or external voltage.. instead, the motor has an internal centrifugal speed controller. This type of motor can be found on older tape decks, and might not have been utilized more recently. Good luck
Mar 07, 2006 | GPX HMTU3234 Shelf System
533 people viewed this question
 Grubhead
Grubhead
