Question about Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard
No display in my board any time massage view memory dumping and view the blue colore screen
    Sergeant:
  • 191 Answers
This may be caused by 2 things: 1. corrupted OS 2.overheating CPU possible solutions: 1. reinstall/repair system using install disc 2. clean CPU fan and apply new thermopaste on base of a radiator ![DON'T scratch the old one with anything sharp, DON'T use alcohol to do it]! then use any temp measurement program to see cpu temp. if above 50 C use a bigger fan
Posted on Sep 24, 2009
Blue screen memory dump
hello, usually memory dump are due to memory timings not properly set. if the memory modules are new i suggest to retrieve the memory timings, and voltage, and then set the parameters in the rack bios. if the memory modules was previously on the machine, could be a memory damaged module/s. anyway try the modules on the machine with a single ram module at time and in any case set the parameters in the bios. hope it help
Nov 12, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
HP 8510p memory dumps "blue
alternate solution
1.install another video software e.g gomplayer
2.upgrade the memory
Sep 22, 2011 | HEWLETT-PACKARD 452218-001 - HP 8510P...
I was just using my mom's acer aspire when suddenly a blue screen appeared that stated it was preparing for a crash dump. The computer will turn on and sound like it's starting up, but then it stops and...
from what yu say if i infer correctly then
when powered on the system powers up properly and the HDD and CPU are running fine but there is no display on the screen and is black,
first try the this step, try connecting an external monitor to the VGA port (generally in blue color) and see if you have a Display on the external monitor.
the black screen generally means that either the Display section is not getting power or the invertor board is damaged and this needs professional help in fixing / replacing it.
hope could be of help
Mar 28, 2011 | Acer Computers & Internet
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Msi 478 socket mother board
to: pubudu,
you said that your ram is ok, but i think it's the ram which is your problem because of memory dumping with color blue. yes your ramis ok but the reason why not ok is because the latency is not compatible with your settings in bios
Dec 01, 2007 | Intel Motherboard
Intel Biostar P4TSE-D2 865 Chipset Mainboard for Pentium 4 533/800 FSB w/ 8X AGP and Serial ATA (MBSK478BIOP4TSED) Motherboard Logo
73 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
