Question about Microsoft Excel for PC
I want an formula in excel to find out number of days present per month an perticular worker
  • 67 Answers
Hello this is Baris,
Can you tell me more about this employee. Are you creating an excel spreadsheet to keep record of his days. Are you just getting the numbers from an outside source like a schedule.
To be able to give you an answer I will assume that you have the info already in the same spreadsheet.
Lets say Column A is the days of the month.
Column B is the information column like the hours that the employee worked. If the month has 31 days this is what you need to do.
Click on the cell B32 and type the formula
=count(B1:B31) and press enter. This will count the number off cells which have a value in it in that month.
If you provide me more info we may come up with a better solution. Hope this helps :)
Posted on Oct 05, 2009
Calculate Quarters between any two dates
not sure if this is what you are after entirely but should at least help you out some what
=DATEDIF(A3,C3,"m")/3
As you said you cant just divide by 3 but I have divided the formula by 3 to see how many 3 months will go into the output you could maybe have another formula to divide it by 2 to see if it will divide by 2 to see if you get a whole number or not, if you do then you can just return the first part before the dot ( using split function ) and if the value is less then 1 then obviously the 3 months has not passed between the 2 dates
May 09, 2009 | Microsoft Office Excel 2003 for PC
Need to know the formula for increasing a $3500 revenue by 0.005% per month for 24 consequtive months. how do i preform this with one formula to avoid entering it 24 different times. i know that the answer...
If the column is absolute, then use the $ before the first character and if the row is absolute use the $ before the second character in your cell designation. If BOTH column and row are absolute, use the $ before both the column and row character.
Examples: $A1, A$1, $A$1
Mar 30, 2009 | Microsoft Excel for PC
VLOOKUP Formula
Using IF function or filter to generate the membership type and create a VLOOKUP for that..... Or using filter function you could create a pivot and insert the specific formula per type in that.
Feb 10, 2009 | Microsoft Excel for PC
How to add % (Percentage column ) in the excel
The formula is 200/700 equals the percentage;if you're in columns a, b, and c, the formula in c1 will look like:
=b1/a1.
Then you can format the cell to show the number (.2857) as a percentage (28.57%).
Jan 03, 2009 | Microsoft Computers & Internet
Microsoft excel Formula
create a dummy column (columnC) containing columnA&columnB
use countif at columnD to count the number of observations per combination of columnA and columnB (in particular those with blank entries in columnB).
Sep 15, 2008 | Computers & Internet
Formula for calculating the days beween months
for example, cell A1 has date (01-01-2008) and cell A2 has current date (08-24-2008) and cell A3 shows total days, is that you want to know? if yes, apply formula as under...
cell A3......(properties set as General to show digits)................ =SUM(A2-A1)
Aug 25, 2008 | Microsoft Office Professional 2007:...
Excel formula.....
Let's start with the 1st equation. I assume you want to be able to recalculate by changing the number of pages.
Put 65 in cell a1.
360 in b1
In C1, put the formula =a1/b1 that's your book thickness
In D1, put .02 for the cover
In E1, put the formula =C1+D1
Now you can change A1, B1,or D1 and the Total thickness gets recalculated automatically. Be careful not to type numbers into C1 or E1, or you lose the formula.
The same for the other equations - a cell for each number ("variable") and another cell for calculations.
Once you've verified the results, then you can get fancy and add titles above each field to make it easy to remember what goes where.
You may need to change the cell format to control the number of decimal places, or thousands commas. Right click on a cell and select format to see the choices you have.
Keep a backup copy of the spreadsheet in case someone (not you, of course) makes a mistake and overwrites the formula cells. You can also look into "protecting" cells to keep them from being changed.
Hope that helps.
Jul 14, 2008 | Computers & Internet
Horizontal
Not sure if I get your problem. Do you mean the SUM() formula with the row does not work?
That is the simplest solution if you are entering the monthly numbers per month.
If you have all these values and need to sum them up based on the current month, you need to use the MONTH() with the NOW() formulas to get a month offset and use a relative reference for the SUM() formula.
Jun 23, 2008 | Microsoft Excel for PC
Excel formula
CHOSE THE PERTICULAR CELL WHERE THE SUM IS GOING TO BE DISPLAYED AND HYPERLINK IT IT WITH SHEET 2
Apr 12, 2008 | Microsoft Excel for PC
Excel Formula
Yes you can and there are two choices. The simple solution is to label a cell "divide by" and put your number in that filed. Then, by changing only that, your answer (in a separate cell) will be available.
There are more complex solutions -assuming your divide by number had some rhyme and reason that could be put in place but.....try this first and at a later date go back and play. Learning to do that will give you more than a fair amount of Excel expertise....something you may find fairly valuable as you continue on using Excel. FYI...I have developed full blown applications on Excel....it is an excellent tool. Hope this helps....Tango.
Feb 05, 2008 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
149 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
