Question about SanDisk Sansa c200 MP3 Player
C200 dont charge
Menu lite turns on but dosent charge i can leave it for 2 days and it says low battery
    Sergeant:
    Champion:
  • 317 Answers
Try changing the battery.
Posted on Dec 22, 2007
My security failed light keeps coming on in my 2002 Jaguar and won't start. What can I do?
hook up battery charger on low amp charge, turn key to run position and leave it on for 20-30 min. then turn key off, wait a few seconds, then attempt to start. if that dosent work, let me know.
Feb 14, 2013 | Cars & Trucks
IPHONE DOSENT TURN ON
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 28, 2012 | Apple iPhone 3G
My mp3 dosent want to turn on and its charged
First try and reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
Ds not turning on ,fitted new battery, amber light
could be a fuse on the logic board blown, probably f1 but if u change one you might as well change both f1 and f2 if that dosent work the logic board needs replacing
Jan 14, 2010 | Nintendo DS Lite Console
Low battery won't charge,change battery,now dead won't charge????
I had the same problem so I got a new battery & separate charger to charge both new & old, then replace as required.
Nov 05, 2017 | Uniden Cordless Phone exai398i
Fujifilm Finepix a825 Digital Camera Battery Life issue
2 long shots as I don't know anything about the a825
Some cameras have a setting in their menu that allows you to choose between alkaline or NiMh (rechargable). If the setting is wrongly set to alkaline when using rechargable it is unlikely to recognise that the batteries are charged and would report low battery. Check your manual to see if their is a select battery setting and check whether it is set correctly.
Occasionally errors on digital cameras can be corrected by removing the memory card and batteries, leaving for 2-3 days and then putting back in the batteries, turning on, turning off, putting the memory card back in and turning back on.
Feb 09, 2009 | Fuji FinePix Digital Camera
No Power when turn on so battery wont charge
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
Jan 05, 2009 | Tripp Lite Smart Pro UPS System
My ds charges but dosent turn on
im not sure but if its hacked, it might be like a psp and get bricked byut not completely sure.
Nov 09, 2008 | Nintendo DS Lite Console
I have questions for any ipod user
What is your problem? The ipod doesn't die. Believe it or not but there's a battery inside of the ipod that if you want it to be repaired. Don't send it to the apple company, they'll charge you a **** load to replace the battery. You can find an ipod battery $10-$30 easy on the net&the proper instructions on the net you can replace the battery yourself!
Jun 28, 2008 | Apple iPod MA446LL/A MP3 Player
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
SanDisk Sansa  c200 MP3 Player Logo
37 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
