Question about Kenmore 71121 Air Conditioner
I have a mitsubishi electric Computer Dehum a/c MSD-09NV but the control handset is not working. where can i get it fixed? I live in TST and cant find a repaiur shop.
  • Kenmore Master
  • 43,501 Answers
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Posted on Aug 20, 2010
Hyundai lantra Lights and power window and aicon only work wen they want too?? Usally after 20 mins of driving they will start to work
What would you like to know ? How to fix ? Do you know anything about automotive electrical circuits ? Go http://bbbind.com/free_tsb.html for free wiring diagrams ! Go to you tube an check out videos on basic automotive electrical trouble shooting , Do you own a DVOM - digital volt ohm meter . also check out videos on voltage drop testing . Then with wiring diagram in hand check voltage drop on the circuits in question . Oh one more thing ,there is probably a module that controls these things , so it wouldn't to have a scan tool hooked to check for codes in body controller . Voltage Drop Essentials TST Motor Age
Mar 16, 2016 | Hyundai Cars & Trucks
I have a Mitsubishi Split model MSH-09NV but not turn on, and the leds are off. The Split not work with bottom emergency neither.
Ensure power supply is correct and you have correct live and neutral and Earth at unit, test power across live and neutral to see voltage at outdoor unit terminals
Dec 04, 2015 | Mitsubishi Heating & Cooling
Why are all my gauges jumping then work again
Lose ground maybe ! check grounding points behind an under dash . Pull the instrument cluster an check power an grounds . Voltage drop test with the circuit on . Voltage Drop Essentials TST Motor Age If you want to fix something like this you need a good under standing of automotive electrical systems .
Nov 10, 2015 | Cars & Trucks
My hanset is nokia 2700 classic. two days before i give the password to my msd card . now i forgot the password and icant opened my mssd card. because i solve mobiles other problem bluetooth cant found...
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Apr 28, 2011 | Nokia Classic 2700 Cell Phone
Cant connect to xbox live
are all the light on your router green? all your cables plugged in? run a connection test. press the xbox guide button. navigate to the far right and click on system settings. now click network then run a tst on your xbox live connection. does your internet work on all your other devices?
Feb 28, 2011 | Video Game Consoles & Games
How do you service Mitsubishi split airco MS-09NV?
What type of service? if it's just cleaning and regular maintence, remove filters and depending on how dirty it is, sparay and brush down eveporator coil, flush out drain line, check all electrical connectios, wash outdoor coil with hose, If you are having problems call a service tech. oh yea wash filter and shake out then re-install
Jan 27, 2010 | Heating & Cooling
Engine run very bad,no 3 injecter get no signal from the computer
I tested the wire from the ECU to the injector, It was oke.I build out the ECU an there was a problem, I smell it . Now a specialist fixed now for me.
Thanks for your reaction .
Andre Chr. Campagne
Jan 29, 2009 | 1992 Mitsubishi 3000GT
Msd distributer
What exactly are you trying to fix? I use the stock type 3-wire distributor in my 68 Mustang and use an MSD 6AL box with a Blaster II coil. What's your truck doing? Why are you going to replace the distributor? Need more info. in order to help you fix your problem. Shoot me an email tiqautoperformance@live.com. I'd be more than happy to help you through your problem. I an owner/operator of an auto repair/hot rod shop. I specialize in Fords.
Aug 25, 2008 | 1995 Ford Bronco
Dehum
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
Jun 25, 2008 | Haier hwr10xc6 Air Conditioner
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Sep 06, 2007 | Logitech Cordless Internet Handset Phone
Kenmore 71121 Air Conditioner Logo
143 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
