Question about Dishwashers
I have a Diplomat Fully integrated dishwasher model ADP 8242 when put on any program it fills and seems to be washing then stops after 5 minutes and the dispenser door has not opened. There is a lot of water left in the bottom of the machine which is cold water. Any suggestions?
  • 909 Answers
Check the small drain pump. Possibly its asking the pump do drain to allow for fresh water, but because low level is not detected it shuts down. The dispenser draw normall opens when the hot wash cycle starts.When you think its washing,briefly open door and see if eater is spraying out of the nozzels.If no water visible, check the main wash motor for sticking
Posted on Sep 24, 2009
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
Dishwasher not working but deeping twice
This is just a guess but it sounds like there is a flow meter on the drain hose somewhere that is bad.
Dec 10, 2013 | Dishwashers
Diplomat Dishwasher Power going off and on
if you are looking for the answers related to your dishwashers problem then you gotta check out this link it's nice and simple easy solutions can solve your problems in just few minutes..
Check them here : Bosch Dishwasher Error Codes E15 E22 E01 E09 Error Codes Pro
Mar 30, 2017 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Jul 13, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Diplomat Dishwasher Model ADP 8132
Please can you give me the dimentions of this Dishwasher Diplomat Model ADP 8132, as I have got to get a replacement and have been told that the Hotpoint FDL570X is the replacement offered,Many Thanks,
Mar 28, 2008 | Dishwashers
Diplomat dishwasher adp 8322
i had same problem and have found that under the lower basket the connecting bar to the spray arm had become detached this can be reattached by inserting the two nozzles back into position and pushing down youll see what i mean ! however i have found i now have to do this after every wash ,am currently onto diplomat to rectify this completely , hope this is any use.
Mar 09, 2008 | Dishwashers
Dishwashers Logo
475 people viewed this question
Top Dishwashers Experts
