Question about Lexmark X5470 All-In-One InkJet Printer
Need to scan on to computer - Lexmark X5470 All-In-One InkJet Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
this is from the manual:
1 Make sure the printer is connected to a computer, and both the printer and the computer are on.
2 Load an original document facedown into the ADF or on the scanner glass.
3 Press Scan Mode.
4 Press or repeatedly until the destination to which you want to scan appears.
5 Press Start Color or Start Black.
6 If you want to save the scan, from the software application, click File and then Save As.
7 Enter the file name, format, and location where you want the scanned image saved.
8 Click Save.
you can find more details in this link- http://www.lexmark.com/publications/pdfs/2007/5400/v3421438_en.pdf
Posted on Sep 24, 2009
Does this printer scanner scan to save to the computer and if it does how do I do that.
What OS are you using? How is the all-in-one connected to your computer. To scan to the computer, you need to install the full software package (if it is available for your OS). If only the OS drivers are available, you will be able to save scans. However, you can only initiate the scan from your computer. Additionally, if you have the all-in-one connected to a print server (or router USB port), the scan features will not work. (The scanner requires two-way communication with the computer and can fail if you use a USB hub, bad cable, or a long cable. Thus try a new cable of less than 6' in length if you can't launch a scan from the computer.)
Next: use the Canon software (MP Navigator EX) and initiate a scan. You will need to adjust some settings to make sure that the program knows what program to open when you press the scan to computer button. The monitoring software will need to be running to identify the button presses. To set this, select Preferences, then the Scanner Button settings tab. Select Actions and then choose Save to PC in the Event drop-down menu. Use the first scan to set the default scan preferences and destination folder. Then click OK to save the settings.
If you do not have the MP Navigator program, use any scanning program on your computer. For Windows 7 and 8, there is Windows Fax and Scan that can work with the MP252. The Apple Macintosh has a similar program. Third party software will also work (Nuance's PaperPort, for example).
See page 318 in the Advanced section of the manual (available from Canon) for screen captures of setting MP Navigator. http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/PIXMA_MP252.aspx?type=manuals .
I hope this helps.
Nov 06, 2014 | Canon Ink Cartridge for Pixma MP252
When trying to scan a photo from the c7280 to the computer the printer displays the following error message No Scan Options : refer to documentation and troubleshoot. This is not covered in my printer...
That's because it's not a printer problem. The scan options are in your computer in the scanning software for your machine. Before you can scan you need to be connected to your computer with scan software running to tell it how to scan, what you're scanning, and where to send and save the image you scan.
Apr 20, 2010 | HP Photosmart C7280 Laser Printer
How do I scan a pic from printer to computer?
Things You'll Need:
  • Computer
  • All-in-one printer
  1. Step 1 Blow the dust from your scanner and printing area with canned air. Clean the scanner bed and the underside of the document lid with a damp, lint-free cloth before scanning.
  2. Step 2 Get your computer and all-in-one printer turned on and talking to each other. Open the scanning software on your computer if needed. If not, you can use the controls on your printer to run the show.
  3. Step 3 Lay the picture to be scanned face-down on the glass. Square up the photo using the guides that are usually located along the edges of the scanning bed.
  4. Step 4 Close the lid.
  5. Step 5 Go for a higher dpi (dots per inch) count if you plan on displaying the scanned image at larger-than-life size. Otherwise, you can select a lower resolution.
  6. Step 6 Click the scan button on your computer's scanning software window. Some all-in-one printers need you to press the scan button on the printer itself; check the manual before using.
  7. Step 7 Get a preview of the scanned image up on your computer monitor. This might happen automatically depending on your software settings; if not, you will have to prompt your computer to display one.
  8. Step 8 Correct small defects such as red-eye in the image. Save extensive changes for later with dedicated photo-editing software.
  9. Step 9 Accept the scan and save to your hard drive. Remember to put your picture away.
Apr 08, 2010 | HP Photosmart C4240 All-In-One InkJet...
Scanning start problem
You need to have the scanning software running first, I use Picaso that comes with some windows.. You open the scan software and tell it what you are scanning and if it sees the scanner you can scan from the computer. If the software doesn't open when you press the scan button you may not have compatible software on your computer.
Dec 08, 2009 | Dell 946 All-In-One InkJet Printer
Push SCAN on my HP6310 and get no scan options
You need scan software running on your computer. It won't scan unless it knows how to scan and where to send the scanned image. The scan options will be on your computer.
Oct 28, 2009 | HP Officejet 6310 All-In-One InkJet...
Need help to setup the scan fuction for Canon Image runner 4570
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
Oct 24, 2009 | Canon Office Equipment & Supplies
I'm trying to scan a document and it says "No Scan Options. Refer to device documentation." It will not scan. What do I do?
In order to scan, you need to be connected to your computer with HP scanning software running. No scan options means it needs to know where to scan to, what format to save in, and what to do with the scanned image. If you want to copy, you just copy, but scanning requires software on your computer.
Sep 28, 2009 | HP OfficeJet J4580 All-In-One Laser...
Scanning
you need an application software to scan a document first, install one from your manufacturer's CD and follw the direction carefully, or if your computer recognizes
go to start-program-accesories-then scanner and camera, see if your computer recognizes your scanner.
Aug 16, 2008 | HP Officejet 6310 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
76 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
