Question about Samsung Televison & Video
How to adjust samsung tv picture alignment using remote
2 Suggested Answers
SOURCE: my samsung ws28a116d remote will only adjust the
To reset the remote so that it works properly again, take the batterys out of the remote, then press and hold the power battery for at least 30 seconds to drain out any power left in the hadnset , then replace battterys and it should work again. We had this fault and this solution worked for us
Posted on Sep 26, 2009
I don't have the remote for a Samsung rear
Go looking for a used remote--I have one I hang onto for just convergence alignments on their sets--no universal will cut this.
The original remotes among other things had a data button to save the adjustments.
May 29, 2012 | Samsung Televison & Video
There are red and green halos especially at the bottom of the screen. Also double images. The alignment procedure using the remote doesn't help.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 21, 2010 | Philips 60PP9363 60" Rear Projection...
I have a samsung 47 inch rear projection w/self focus there is a continuos blue shadow around images is there a quick fix
The blue is caused by the RGB gun alignment. Green is a fixed gun and Red and Blue are adjustable. In my Mitsubishi, the guns are motorized and can initially be adjusted (course) with the remote. There are more detailed adjustments that can be made if you purchase the service manual. I paid approx $19.00 on line 3 years ago and it is a complete manual. Unfortunetly I don't remember the site. To do a complete alignment, there are steps to take: starting with entering a code using the remote to enter the setup. To make a long story short, I had my tv aligned 3 or 4 times over 5 years under the extended warranty. After watching the tech, who was good, but under time constraints, it was clear that most anyone could do it if they could read and follow instructions.
Mar 05, 2010 | Samsung Televison & Video
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence is scrambled due to power outage. how do i use remote control to get into service mode to do a "course convergence adjustment" ?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Dec 10, 2008 | Panasonic PT-47WX53 47" Rear Projection...
I have A 60 philips projection tv with triple picture
Don't adjust anything from the rear of the set unless you are a TV repair tech. It can get ugly real quick.
Try adjusting the convergence using your remote...Pull up the settings menu - goto picture - convergence - etc....See if you can adjust the color alignment back to normal. If not your convergence chips are most likely going out.
Nov 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
How to manually adjust the centering of the picture
On newer televisions the centering adjustment is only in the service menu. I wouldn't suggest anyone accessing it unless you understand all of the abbriviated alignments.
Feb 21, 2007 | Samsung TX-R2035 TV
Televison & Video Logo
853 people viewed this question
Henry  Thomas
Henry Thomas
