Question about Cell Phones
My htch screen touch not working. Bcoz of this several function related to screen touch unable to be performed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
Do the basic- turn the phone off and remove the battery for one night. if this doesn't help, then probably the board inside the phone is damaged and needs to be replaced
Posted on Sep 24, 2009
My touch screen on my ex 119 is only pressing and i'm not getting the touch at the bottom of the screen
I would send it back to the manufacturer, it sounds as though you may have a defective phone or cell phone.
Oct 06, 2012 | Motorola Mobility Ex119 Ex-119 Dual-sim...
My T Mobil Samsung Galaxy T cell phone's touch screen will not operate.
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
Jun 28, 2012 | T-Mobile My Touch Cell Phone
My Nokia N8 touch screen has frozen, the other buttons that aren't part of the actual screen work but anything related to the touch screen won't work at all. And I just bought the phone all brand-new a...
if your have warranty on the phone please bring it back to the store where it was purchase bcoz if the touch screen is messed up there is no way for the phone to work properly
Mar 29, 2011 | Nokia N80 Cellular Phone
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
The touch screen randomly stopped working, & isn't letting me call out/receive calls! it will force close out of pretty much everthing! I admit to dropping it a lot.. but it alwaysed worked after!, I...
hi
there must be the display gets damaged in your phone. change the touch display of your mobile screen and format the phone this will able you to fix this problem.. just change the display screen of your mobile..
thank you
Dec 20, 2010 | HTC G1
Touch Screen fails to work
get it serviced?
my guess, damaged screen.
most shops would touch any Ipaq.
why not ask on a real HP forum?
my guess, the only hope for old Ipaq
http://h30434.www3.hp.com/
May 10, 2017 | HP iPAQ hx2190 Pocket PC
Screen got locked
you can try to upgrade the software or at least install it again.
this will solve the problem if it caused by a missing dll related to screen functionality
Dec 16, 2008 | i-mate K-jam Smartphone
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
Messed up with garmin
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Sep 03, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
May 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Cell Phones Logo
115 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
