Question about Samsung AW0693L Air Conditioner
Airconditioner stops, we have not set timer. It restarts after some time say 10 minutes. In between it does not start even if you start with remote control. What is the fix
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: My airconditioner is cooling only for 10 minutes
Check the thermostat located on the front of the unit and also is the compressor running when the cooling stops?
Posted on Apr 25, 2009
  • 400 Answers
SOURCE: LG Split Ac LSA5NF5VFC1 Compressor Stops after every 7 minutes.
One possibility is that it is short of refrigerant and is short cycling due to the low pressure cut out switch? Hope this helps.
Posted on Aug 20, 2009
  • 3247 Answers
SOURCE: I have a SAMSUNG Split
It might help if you can confirm whether the unit is running in heat or cool mode when you observe the problem.
Do you actually hear the compressor in the outdoor unit start before the indoor unit stops blowing air?
Please confirm.
Is your user manual like this?
Posted on Sep 25, 2010
  • 222 Answers
SOURCE: how to restore factory settings
check the batery of remote if is new one,replace the battery coz all remote is sensitive to vibration do to misuse.
Posted on Dec 24, 2010
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
How do I change the clock on a oxo digital timer?
I'm assuming that you're referring to OXO's Digital Timer Model #1061978. OXO doesn't provide a copy of the instruction booklet for download, but I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Aug 19, 2014 | Hardware & Accessories
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Mar 26, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Samsung AW0693L Air Conditioner Logo
37 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
