Question about Intel Motherboard
Tempremental bootups GIGABYTE GA-7VT600P-RZC Only boots up sometimes, other time it turns on but does not beep and boot up??? Workd fine when it is just the hard drive plugged in with nothing else in the ide. Is it the ide controller? is there anything I can down load to help this?
  • 104 Answers
Check the jumper settings on all the ide devices and be sure are correct. Also check cables and connections to be ok. u may also try another memory module as a faulty one could also cause failed boot
Posted on Sep 25, 2009
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
I have a Gigabyte 7vt600p-rz motherboard. How do i disable the Bios Security password on it so i can change the boot sequence ?
Clear cmos, you should have a clear cmos jumper on your motherboard, just move the jumper from the normal position to the clear cmos and then back. Or you can remove the lithium battery for atleast 15 min.
Nov 17, 2010 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
Hello, I recentily buy a GIGABYTE GA-EP45T-UD3LR motherboard, it workd great, but don't have the "beep" sound when boot, I test via software the internal speaker and it works, is this correct ?, I hear...
1 beep is the BIOS signaling all is well after testing components inside and attached to the pc. On newer motherboards it's heard only when you have something attached to the USB connectors . Do a simple test: boot with an connected USB device, like a running printer or an memory stick - you will hear the short beep as you were used to.
Apr 13, 2010 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
GA-7DPXDW-P motherboard will not boot or beep
Make sure that power cord from the power supply is seated in good. If that don't make it boot or beep sounds like your board got toast by some surges.
Nov 15, 2009 | Gigabyte GA-7DPXDW-P Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
May 03, 2009 | Gigabyte GA-K8VM800M Motherboard
7VT600P-RZ does not boot!
Sounds like a cabling issue with the drives. From the description, you are running PATA (parallel) interface drives, using ribbon cables. Make sure you cabled the master to the master drive, and ditto for the slave. They are easy to reverse.
From what you say, the system is recognizing your optical drives, since you can attempt a reinstall from one of them. That really does point to a cabling issue with the hard drives.
As another diagnostic tool, try removing the slave drive, and see what happens.
Cheers
Nick
Jan 10, 2009 | Gigabyte 7VT600P-RZ (GA7VT600PRZ)...
No beep tones on startup, power to all devices, no bootup
Just a shot in the dark...unplug power, remove battery..at least an hour . Press power button at least once in the hour.
Good Luck
Apr 04, 2017 | Gigabyte GA-N650SLI-DS4 nVIDIA nFORCE 650I...
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
