Question about Vehicle Parts & Accessories
Broken Sensor Sterling Touch Immobiliser
I have broken the dash mounted immobiliser touch sensor on my Hilux Surf.
It is a Sterling 'Touch' model. I seem to note that the transponder end has three wires on a multiplug (red black & blue) whilst at the dash end there are four (red, black, & TWO blues). Do you have a wiring diagram to explain the missing blue wire?
There are 4 wires going to the touch pad unit which has an LED in it. The unit has 4 pins (or legs) to which the wires must be soldered. As you say, there are two blue wires plus a red and also a black - although as you also correctly observe, only three wires are present (blue, red and black) in the connector at the other end of the loom which plugs into the control module.
The blue simply splits two ways within the loom, and these are earths. The black carries a pulsing voltage to drive the LED, and the red (which should measure a constant 5v on a voltmeter) is an input which senses when a key is touched on the pad.
Use a continuity tester or ohmmeter to establish which of the four pins on the touch unit connects to the CENTRE pin of the touchpad. Solder the RED wire to this pin. (Best to start by putting some heat shrink up the wire as the pins on the touch unit are quite close together and there's not much to stop them touching.)
Again using the continuity tester (or ohmmeter) establish which of the remaining three pins goes to the OUTER ring of the touchpad. To this, solder one of the BLUE wires - it doesn't matter which one. You must however get the wires to the touchpad the correct way around in order for the key to be read.
You're now left with one BLACK and one BLUE wire which drive the LED, and two pins on the unit which have no connections. The LED will only light when you get these the correct way around. You will not do no harm if you connect them the wrong way round - the LED will simply remain unlit.
One you have soldered the BLUE and the BLACK wires in place so the LED is flashing, simply test your work by touching a key on the touchpad. If all is well, the LED will light continuously for a period and it should be possible to start the car.
Posted on Jan 05, 2015
4 Suggested Answers
reynosaelect
  • 165 Answers
SOURCE: alarm/immobiliser
i cant help you but i need to send you by fax the information,email me reynosaelectronics@live.com.mx send me your fax number.
Posted on Mar 17, 2009
SOURCE: I have a thatcham TE2-1331/0305 I want to fit in
My 2005 Dodge Caravan head lights and dome lights stays on a little longer then the norm. Also the chime indicator that lets you know that you left the lights on or you left the keys in the ignition comes on as soon the door is open.I have had one battery go dead on me . Can't afford to be replacing batteries when they go dead on me! Can you help?
Posted on Jan 04, 2011
tayjoejoe
  • 2215 Answers
SOURCE: install vats bypass
Here is a link that may help you out
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Mar 16, 2012
1998 Saturn sl2 died while driving. Lights on the dash board come on when I turn the key, but then engine doesn't crank or start
run the fault codes and check for cam/crank position sensor failure
check that he cam shaft is turning ( broken belt)
check immobiliser operation
Jul 31, 2015 | Saturn Cars & Trucks
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
Ranger 2.2 diesel turbo. Where can I get a wiring diagram for the engine?
run the fault codes
it may be a broken cam shaft , cam/crank position sensors or immobiliser not operational
don't touch the wiring until you have the fault codes.
May 29, 2015 | Ford Cars & Trucks
Why the car shutoff while driving
First thing to check is that the cam shaft is still turning ( broken timing belt/ chain). Check battery terminals are clean and tight as a broken circuit will shut down the immobiliser . Run fault codes to check for sensor problems.
May 26, 2014 | 2003 Saturn ION
A small nob which deactivates the immobiliser in my Daewoo 2001 nubira has broken in to poeces. Can some one help me start the car by bypassing the immobiliser?
if that knob has 2 wires going to it u can join the 2 wires together or touch them together to deactivate immobiliser , the knob is a switch that either connects the 2 wires or disconnects them when pushed ,if there are more than 2 wires i would need to know the colours and how many there are
Jan 15, 2014 | 2002 Daewoo Lanos
Suzuki baleno no spark
did you check to see if the cam shaft is turning ( broken timing belt)
Dec 26, 2013 | Cars & Trucks
HELP i have a 2000 model hyundai lantra sportswagon which is fitted with an immobiliser and both remotes are broken. How can i bypass the immobiliser???
theres a socket you can use to reset the immobilizer. follow the steering shaft down, then under the dash, you will find the socket. plug the key switch with the button facing away from you, while the ignition is switched on.I'm pretty sure it doesnt matter if the remote is broken or not, as it just bridges the circuit, allowing you to start the car. hope this helps..
Oct 01, 2011 | Cars & Trucks
Broken immobiliser remote
usually there is a bypass switch somewhere under dash,or contact person or place that installed it
Feb 15, 2009 | 1999 Hyundai Accent
Starting problems
get the crank sensor (TDC sensor) replaced. It is a very common problem on Renaults. Join us on Renault Forums. Cheers
Nov 14, 2008 | 2001 Renault Sportwagon
Cobra 8510 immobiliser fitted to my ford excort rs turbo
Wheelsnboots
When you say the Immobiliser is broken... Do you mean the touch key?
The 8510 touch key is prone to the internal contacts failing. If you open the case up and reconnect it then you should be able to disarm the immobiliser
You should have two touch keys so try your spare on first.
Be warned... You will need 1 working touch key to program a spare or the system will lock out and will need replacing
Hope this helps!
As for Sutty
Sounds like the system has lost power if the LED is not flashing. Have you made sure cars the battery is not flat?
May 05, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
313 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
