Question about Neff B1421 Electric Single Oven
The oven packed up on me yesterday.The grill heater still works, also the fan and timer. Is it repairable and at approxiamate cost. I cannot afford another Neff oven. It is barely 6 years and this is the first problem I've had with it other than the light not working after a very short time, which I've managed without. Many thanks for help with this problem
  • 909 Answers
You have a very good chance that it could simply be a faulty oven elemenr or burned wire or even an over temp. cutout switch. Have it checked by the technician and possibly get a quote..(When repair is done, you want to see faulty items).
Posted on Sep 24, 2009
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
Should I chuck out the cooker because the oven timer does not work?
Believe or not a lot of consumer items are this way nowadays. It sorta like push mowers where the repair parts, shipping, and labor cost as much as a replacement mower. It so expensive just get parts in from China and other places for the items they are just dumping on us that it is more cost effective to just to replace items that are out of warranty.
Oct 16, 2014 | Ovens
Heating elements in fan oven not working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 26, 2011 | Smeg Ovens
Hi Our oven wont turn on, has power as the display panel has a little "A" luminated on the left of display screen but nothing else operates, no fan, Grill, timer. please advise
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Mar 24, 2011 | Smeg SE210X/1 Stainless Steel Electric...
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
How much should it cost for my element in my oven to be fixed i have the element just the instalation needs diong
Jan 18, 2011 | Smeg DO 10PSS Stainless Steel Electric...
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Neff B1421 Electric Single Oven Logo
322 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
