Question about DeVilbiss Air Tools & Compressors
JGA Siphon feed The Gun Pulseates with fluid running through it
  • 3,600 Answers
The tip is dirty and plugged try cleaning the gun is spray gun cleaner. If you would like more information just post here and I will answer.
Posted on Oct 02, 2009
Spitting
most paint spray guns require the paint to be thinned this may be the cause of the spitting
Apr 15, 2014 | DeVilbiss Jga-510 Paint Gun Sprayer Item...
On a Campbell Hausfeld DH5030 spray gun, there is a screw valve at the base of the unit with arrows labeled S and P for turning clockwise and counterclockwise, respectively. What is this for?
The "P" stands for pressure feed. turning it completly to this side forces air into the cup pushing the paint out.
The "S" is for siphon feed where the air through the tip sucks paint from the cup.
If your using thin materials like lacquers or polyurethane or solvent based enamels the siphon feed is used.
If your using thicker materials like water based latex or heavy stains then go with the pressure setting.
You can always go in between for some pressure with the siphon action....depends on coatings used.
Jun 22, 2011 | Campbell Hausfeld DH5300 General Purpose...
Hi After shooting my 4 + 1 primer ( 4 coats ) Via a Trans tech 110 and 1.4 tip I wet flat with 800 but kept breaking through the primer seeing the gel coat underneath even though I was applying only enough...
Im a spray painter it sounds like there is some type of sheen on the primer what are you trying to finish wood metal why 4 coats of primer what kind of finish are you applying over it Get back to me i have been doing this for 40 years will see if we can figure this out
Jan 06, 2011 | DeVilbiss 1.6mm Fluid Tip - Devilbiss...
Air pressure out through the suction tube of liquid my spray gun - DeVilbiss jga 558
If your getting air down the suction pipe your air cap isnt tight enough or its the wrong one.
Oct 21, 2010 | Air Tools & Compressors
Siphon tube on cup gun blows into the cup
Other than a missing or deformed gasket ring around the nozzle assembly, there might be a gun casting leak from the air passages to the fluid passages. Hope this helps!
Apr 02, 2010 | Binks SPRAY GUNS & OUTFITS
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
What are the controls of a gravity fee spray gun
most spray guns are basically the same gravity feed is no different, air pressure into gun and out nozzle,spray pattern fan to spot and last the amount of fluid comin out of cup to the nozzle.
Aug 28, 2009 | Ingersoll Rand 1.4MM HVLP GRAV FEED SPRAY...
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Thiner how to
Paint to thinner ratio is 60:40, that is 60% paint and 40% thinner. Sometimes it can be 50:50 depending on different occasion. Remember to MIX IT WELL.
Aug 27, 2008 | Viking Spray Gun: Hvlp Siphon Feed Spray...
Air Tools & Compressors Logo
296 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
