Question about Garden
Got a Ryobi Petrol grass trimmer but cant start i anymore as there is no resistance on the cord when trying to start it. Any ideas?
  • 279 Answers
Sounds like the starter spool is stripped. This the one with the cord on it. You have to dismantle the unit to replace it but it is not too hard. You can get a replacement online or ot your local small engine shop. Good luck...Lee
Posted on Sep 24, 2009
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
The strings keep on breaking off at the eyelet
Usually means grass is too long for that trimmer or you are cutting too close...try trimming with just the tip of the cord...or eyelets are worn sharp
Aug 08, 2010 | Ryobi 18v Lithium Grass Cordless Trimmer...
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 25cc Ryobi grass trimmer I have lost the manual. I would like the fuel ratio of petrol to 2 stroke for this trimmer
http://odref.com/pdf/Ryobi/
If you have your model number, an owners manual should be here with correct mixture ratio for petro to 2 stroke oil.
Sep 14, 2009 | Ryobi Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Manual for Ryobi Grass Scorpion Line Trimmer
my ryobi scorpion only has twofuel lines but two on primer can you help
Mar 13, 2009 | Ryobi Garden
Please help me to stat this thing I have no manuel
When I first got my brand new RYOBI LIne Trimmer the *** thing just would not start. I was following the exact guidelines in the maual. First thing is, ensure you get right is fresh fuel correctly mixed accurately with 2-stroke oil. Some machines are more temperamental about the mix. 2. Set choke to COLD, press bulb 8 times (once you see fuel enteing the clear bubble reservoir) 3. Switch on power. It's amazing how often I've pulled the cord with that red button off. Dont think you cant do it to. 4. Pull the cord gently until you feel resistance. Let it gently recoil, then in one non-aggressive move, holding down the unit with your other hand, pull it out at constant speed. Do not yank! If (or rather when) it doesnt start, pull the accelerator trigger a couple of times only, and repeat procedure "4". Don't press bulb again too often or use the trigger too early or you will flood the engine. When I couldnt get my strimmer to start at all, I got this advice from an online engineer, it fired up *first pull*.
If it's not starting after a winter rest, did you store it empty of fuel because that is always wise. Discard old petrol mix and start with new. Hope that has helped.
Mar 04, 2009 | Ryobi 15" Electric Factory Reconditioned...
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
