I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE. Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason. Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear. Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
i have an 8gb usb memory stick now it is not work everytime when i connect it it does show but when...
(More)
i have an 8gb usb memory stick now it is not work everytime when i connect it it does show but when i try to open it, it says the disc is not formated and when i try to formate it it says the disc is protected
It's all hooked up OK. But How do I start using it. Do I have to instal something else? Where's a...
(More)
It's all hooked up OK. But How do I start using it. Do I have to instal something else? Where's a blank page I can save data to? It's all icons & more icons.
3200MLBP sends frequent error msgs, "failed to eject", while using this HD as the...
(More)
3200MLBP sends frequent error msgs, "failed to eject", while using this HD as the "Time Machine" backup drive for my G5 Mac 10.5.8
Maxtor one touchII The computer reconizes and can change some settings, but I can't access the setup...
(More)
Maxtor one touchII The computer reconizes and can change some settings, but I can't access the setup page. It's the only button that isn't grayed-out, but the setup screen never appears.
i HAVE A ACOMDATA EXERNAL DRIVE IT LIGHTS UP BUT NOT ABLE TO RETRIEVE DATA AND COMPUTER DOES NOT...
(More)
i HAVE A ACOMDATA EXERNAL DRIVE IT LIGHTS UP BUT NOT ABLE TO RETRIEVE DATA AND COMPUTER DOES NOT RECONIZE THIS DRIVE
