Question about Makita HR2450F Rotary Hammer
Wanted free makita hr2450 manual to repair selector switch which is not locking in position
I want free maitenace manual
Posted on Sep 28, 2010
  • V31JP Aug 04, 2011
    There is no maintenance manual, only user manuals. The parts break down though is the next best thing available to understand how it is put together.
    President:
  • 267 Answers
HI,
THIS WILL HELP YOU
http://powertool.manualsonline.com/manuals/mfg/makita/hr2450t.html
thank you,
vijay (vote for me)
Posted on Sep 24, 2009
  • Makita Master
  • 1,803 Answers
Its also a manual if the other will not working
Makita HR2450 Parts List
Posted on Apr 17, 2016
My 2006 Ford fusion does not release the key from the ignition when it's in park???
You have a problem with THE SHIFT INTERLOCK SYSTEM !
The floor shifter assembly:
  • locks the transaxle range selector lever in the PARK position when the ignition switch is in the LOCK position.
  • requires the transaxle range selector lever to be in the PARK position to turn the ignition switch to the LOCK position.
PINPOINT TEST A: THE SHIFT INTERLOCK SYSTEM DOES NOT RELEASE/LOCK CORRECTLY
A1 TEST THE BRAKE LIGHTS
  • Apply the brake pedal and view the brake lights.
  • Do the brake lights illuminate?
Yes
GO to A2 .
No
REFER to Section 417-01 .
A2 TEST SHIFT INTERLOCK ACTUATOR POWER CIRCUIT
  • Disconnect: Floor Shifter Harness Connector C3245.
  • Key in ON position.
  • Measure the voltage between floor shifter harness connector C3245-1, vehicle harness side and ground, while applying the brake pedal.
    Is the voltage greater than 10 volts?
A3 TEST SHIFT INTERLOCK ACTUATOR GROUND CIRCUIT
  • Key in OFF position.
  • Measure the resistance between floor shifter harness connector C3245-4, vehicle harness side and ground.
    Is the resistance less than 5 ohms?
Yes
INSTALL a new selector lever. Refer to Selector Lever in this section.
No
REPAIR the circuit. TEST the system for normal operation.
May 25, 2015 | 2006 Ford Fusion
The linkage are hooked up but the car still want go into park,a 2000 Taurus
Do you have floor console shifter ?
Shift Interlock System A brake/shifter interlock system consists of the following:
  • ignition switch (11572)
  • brake pedal stoplight switch (13480)
  • brake shift interlock module
  • brake shift interlock solenoid assembly (attached to key interlock assembly)
  • necessary wiring
On floor-shift vehicles, the ignition/shifter interlock cable (3F719):
  • locks the floor shift transaxle range selector lever in the PARK position when the ignition switch is in the LOCK position.
  • requires the floor shift transaxle range selector lever to be in the PARK position to turn the ignition switch to the LOCK position.
May 04, 2015 | 2000 Ford Taurus
How do i lubricate my makita hr2450 hammer
193606-2 its the neccesary service kit for the tool with all the parts but be aware to control the locking sleeve and impact bolt replace it if its not air tight
Apr 26, 2014 | Makita Hammering
Hr2450
Clutch and or the drive dogs on the primary drive.
Jan 12, 2014 | Makita Drills
What do codes p0707 and code p0708?
1. Place the selector lever in the "N" (Neutral) position.
2. Loosen the manual control lever lock nut to separate the cable and lever.
3. Place the manual control lever in the "N" (Neutral) position.
4. Turn the transaxle range switch body until the 12 mm (.47 in.) wide end of the manual control lever aligns with the switch body flange [12 mm (0.472 in.) wide portion].
5. Tighten the attaching bolts (2 pcs.) to the specified torque. When setting up the switch body, be careful O-ring does not drop from the switch body. Tighten the attaching bolts carefully.
6. Make sure that the selector lever is in the "N" (Neutral) position.
7. Adjust the flange nut so that there is no slack in the control cable and make sure that the selector lever operates smoothly.
8. Run the vehicle and confirm that the transaxle is set in each range when the selector lever is shifted to each position.
for more help visit https://cbrtechsolutions.net
Jan 25, 2013 | 1997 Mercury Sable
How to remove wires from the switch from makita hr2450 hammer drill
Use a fine jewellers screwdriver or thin stiff wire in the small holes next to the wire holes.
Dec 07, 2012 | Makita HR2450F Rotary Hammer
I have a Makita HR2450 hammer drill with an SDS chuck. It no longer holds the bits tightly and I can now push them in and pull them out without needing to use the release mechanism. How do I remove the...
go to Makitatools.com and type in your model number for a breakdown. What I would do is first remove the dust shield and under that you will find a retaining ring, remove it without spreading it too much, then remove the collar and under that you will find a washer and another retaining washer, push down and remove the steel ball. clean the area, it could be full of dirt and not locking properly. Let me know if you need more assistance
Sep 12, 2010 | Makita Drills
My 18v cordlass drill moter runs but will not
Your selector slide for the gears may be broken. If it is broken you will have to replace the transmission unit cause they don't sell the individual parts. Or it could be that your selector slide is off a little, try shifting the selector into the different positions. If it is not locking you are missing the little retention spring that rides along the side of the selector. In this case all you need to replace is the spring. Any questions please post back.
Nov 16, 2009 | Makita 18V 1/2"CRDLS Drill Kit
Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Makita HR2450F Rotary Hammer Logo
1,264 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
