Question about Acer Aspire One PC Notebook
Lan and Wireless show they are connected but no data passes
I have two AspireOne notebooks. One works perfectly, the other worked for about 20 days. Now it will not pick up any assigned IP addresses from my router either on the lan or the wireless. Both indicate they are connected, but the Status window shows no data recieved or sent.
I took it back to the Base Exchange where I bought it, but they refused to help.
    Scholar:
  • 131 Answers
There are many different reasons that this can happen. Could be your wireless router or something in your laptop settings.
Try this:
1. Click start -> type "cmd" (without quotations) press enter.
- In the command prompt type this: "ipconfig /release" (without quotes)
wait for it to release your ip: Then type in same command prompt: "ipconfig /renew"
This should release your ip address then renew it. If this does not work, then it may be your wireless router. There are 2 things you can do here as well. You can either take a cable and plug it into your laptop and into your router. See if you can access the internet like that, if not, then you may have to find something small like a ballpoint pen and press and hold the reset button on the back of the router for 10 seconds. Then remember to redo all your settings on your router. Your manual will tell exactly how to login to your router, as this can be different with every one.
Hope this helps.
Posted on Sep 24, 2009
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
The Linksys E1000 wireless-N Router will not work on my AspireOne notebook computer. It only works with the ethernet cable. What should I do?
Your computer is an 802.11g type wireless and your E1000 is an 802.11n type.Whilst these two different wifi standards can be used in conjunction with each other, the N type can cause significant interference to G type networking equipment. Furthermore, an N type network's performance will be degraded if a G type device joins it. Sorry to be the bringer of bad news :(
It may be a better idea to buy a new N type USB adapter for your notebook if you want to stop using the LAN cable.
If this has helped resolve the problem then can you please rate my answer - thanks :)
Oct 19, 2010 | Computers & Internet
My laptop used to connect to the wireless connection , but one day it stopped working and now i can only connect to internet using a lan cable
go into the device manager and uninstall the wireless adapter. Then click scan for hardware changes and let windows resinstall it. It sounds like a corrupt driver. Before doing so make sure you didnt hit the wireless button that shuts off the connection on the computer. :)
Joe
May 26, 2009 | HP Pavilion Tablet Notebook
Can´t get an IP valid address on a Toshiba a65 with a Realtek LAN NIC Card that shows well installed, working, perfect a properly reconignized within the system, although there´s no error showing...
Power off your wireless router for 30 secs. and power it up again wait till all the LED are on and functioninh normally.
THEN
Reboot your laptop OR
Right click on the wireless icon and click on Repair - this will force the wireless card to obtain a new IP address from the wireless router.
May 02, 2009 | Toshiba Satellite A65-S126 Notebook
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
Feb 13, 2009 | Toshiba Satellite M35X-S161 Notebook
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Acer Aspire One  PC Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
