Question about HHP Hand Held Products IT3800LR-12 Barcode Scanner
How will i connect hpp IT3800LR to pc using the serial and usb connector?
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
What printer do I use to connect an Officejet d135
A printer does not connect to a hard drive.
Is the connector on the PC a Male (Parallel) or Female "D" (Serial) shaped connector?
Does the PC have a flat USB connector you can use?
If it does, then you should be able to purchase a cable that has an "End Point Connector" The "U" shaped block and the other end is the flat conector that is oon just about everthing.
Don
Feb 06, 2010 | HP OfficeJet D135 All-In-One InkJet...
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
I just bought a used sp300 star printer. I dont understand how to connect the serial interface connector to my hardrive. Please advise.
I would buy a usb to serial connector. I had to buy one in order to configure a biometric lock that had a serial connection. The usb cable with serial at the end worked way better.
Oct 17, 2009 | Star Micronics SP300 Matrix Printer
Mouse freezes
Is it wireless mouse or usb? or serial connector? if its usb mouse try to use different usb port and check the status, if its wirless it will be connection or battery problem, try to charge it, if its serial connecter try change the mouse . Or use the keyboard port for mouse and see the difference. if all this not work let me know so i can show you the windows steps in order to fix it.
Best regards
Mar 02, 2009 | E-Machines eMachines T3830 PC Desktop
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Solution
Since you havent got USB (I assume an older or non functional usb port) buy a serial data cable with one end the serial connector and at the other end the mini usb connector to plug in the phone.
I dont know your location but these can be found for app. 20$
You have to use software as well such as Motorola Mobile PhoneTools which is free.
Mar 27, 2008 | Motorola Mobility RAZR V3
Does Axim Have a serial Connector
From what Dell shows in their downloadable manual there may be a fabled serial connector from the cradle and the travel cable. Dell does not offer it at this time. I only read once that Dell may offer if Mid Jan. I would bet that you would have better luck waiting for an aftermarket company to make one *IF* the unit supports serial. I honestly don't see why Dell wouldn't offer serial but there is always that chance that they will support USB only. I have yet to receive my unit.
Sep 14, 2005 | Dell Axim X5 Pocket PC
HHP Hand Held Products IT3800LR-12 Barcode Scanner Logo
42 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
