Western Digital 500GB My Book World Edition 500 GB Hard Drive
Problem for Western Digital 500GB My Book World Edition 500 GB Hard...
I didn't dropped it and the connections are like it
By sabas_gre on Sep 24, 2009
I didn't dropped it ; the connections are like they always were but out of nowhere it just wont boot up.the pc is fine ; i can hear the sound of boot up a bit and i can also ''feel'' the hd inside working but it wont boot up and the blue-ring light won't flash.What should i do?
Solution #1
posted on Sep 24, 2009
Not Rated)
bob_computer
Rank: Guru  Western Digital Computer Accessories  Expert
Rating: 87%, 1389 votes
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Was this helpful?
Yes
No
Popular Solutions for Western Digital 500GB My Book
Questions and Unsolved Problems for Western Digital 500GB My Book
Do you recommend Western Digital 500GB My Book World Edition 500 GB Hard Drive?
Answer
Answer
My WorldBook is on my home network. Sometimes I can see it on the network tree, othertimes I cannot.... (More)
Answer
unable to read data on my book drive although all lights are on
Answer
I have a WD MyBook backup drive. It has not successfully backed up since Sept-Oct. When it tries to... (More)
Answer
very slow to open files, several do not open. does not allow deletion of files, all files affected... (More)
Answer
I have a WD 500GB My Book World Edition and only need to use it for back up...problem: I've hooked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
in , IL
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
