Question about Impact Receipt Printer, Dot Matrix, 42 Column, SERIAL interface, 3 inch print width, 3.1 lps (lines
Where do I clean in my HP PSC 1350 printer to stop smudgy broken lines being printed on the extreme left of the paper?
    President:
  • 267 Answers
HI,
This will help you out it contains service manuals please do it fully http://www.devicemanuals.com/guide/Printers/HP/HP-PSC-1350-All-In-One-Reference-Guide-==TVRJMk5UazE=.html
thank you,
vijay (vote for me)
Posted on Sep 24, 2009
My HP psc 1350 all in one printer scanner copier keeps saying paper jam, how do I clear status on my computer when I have fixed all paper jams and printer says clear?
I suggest you uninstall the printer and disconnect it from the mains and from the computer. Restart your computer a couple of times and then reinstall the printer.
I have used HP printers quite a bit and find them reliable if they are left alone but if I try and interrupt their work by cancelling a print once it has begun or even by attempting to continue working on the computer while it is printing it starts acting like a crazy person and won't stop until it has been switched off for about half an hour. All my HP printers have been the same in this respect...
Jun 13, 2016 | HP Psc 1350 All In One Printer Scanner...
1350 "out of paper", but there is paper in the tray.
If the printer is making noice as it is preparing to print but does not take paper, then it has broken gears inside. Disasembly takes a lot of time and the spare part is called "printer mechanics" which is the half of the printer.
Apr 08, 2012 | HP PSC 1350 All-In-One Thermal Printer
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
My printer (HP PSC 1350) says there is a paper jam but I have taken the paper out, taken the back off and there is no paper jam. Is there a way to reset it or something?
hi
unplug the printer from power source
open the upper cover
move the CR cartridge carfully at the right position look inside is there any broken pices
Oct 27, 2010 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Nov 03, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp 1350 all-in one psc
your paper feed problem may be due to the feed rollers or due to the fact the mecanism that raise the paper doesn't function properly. Normally if you clean the rollers that should work
Jan 25, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1350 printer
i cannot re-install my hp 1350 all in one scanner. i have uninstall and re-install the printer driver was unknown. how can that be possible even i dont have the cd that comes with it.
Feb 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350
Try cleaning your printer and its rubber rollers. Also make sure there is no object stuck inside the printer that prevents the printer from loading the paper smoothly. may be you have no other problem.
Oct 24, 2007 | HP PSC 1350 All-In-One Thermal Printer
Impact Receipt Printer, Dot Matrix, 42 Column, SERIAL interface, 3 inch print width, 3.1 lps (lines Logo
136 people viewed this question
Top Impact Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Impact Office Equipment and Supply Expert? Answer questions, earn points and help others
