Question about Reddy Heater-30-55,000 BTU Variable
30000 & a50000 btu reddi heat
Both run for a little while then start burbing and chokeing me out like it is running out of fuel
  • 625 Answers
In the fuel line is a disk type filter see if its clogged. air compressor pressure should be 3.0 - 3.5 psi.
Posted on Dec 16, 2007
Reddy Heater
check lines for blockage
May 30, 2017 | Reddy Heater-30-55,000 BTU Variable
Had my kereosene 90,000 btu heater running yesterday and shut it off.plugged it in today and all it does is spit raw fuel out the front.i take the spark plug out and try to ground it i can't see any spark...
ruppguy,
All the time.
You have a classic reddy heat problem. They use a system which sets the fuel pump pressure with bleed air. Comes out the back where there is a screw. If the pressure is not 4.5 psig the pump will pump too much or in your case too little fuel. This happens when the air filter plugs and changes the ratio. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts at the best price.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy heater 40000 btu ker/forcedair plug it in it takes off for a little while then shutsoff
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Types of fuels
YOU COULD RUN ON # 2 HEATING OIL BUT WOULD NOT RECOMMEND DIRTY AND MORE LIKELY TO GUM ALSO DOES NOT GENERATE SAME BTU PER GAL I WOULD STICK WITH KERO
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater won't stay on
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Nov 19, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
104 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
