Printer hangs and gives a message"MEM FAILURE REPLACE DIMM 0"
Hi expert, My printer hangs at the start and gives a message as" MEM TEST FAILURE REPLACE DIMM 0"
Emmanuel
    Scholar:
  • 199 Answers
Remove the DIMM memory from the formatter board and clean dimm memory contact (use ip & soft cloth) and check.if the problem continues change the dimm
Posted on Sep 24, 2009
    Sniper:
  • 70 Answers
As it says the memory has a problem, if your printer is an hp laser jet then you can find it on the side of the printer, just open the side panel of the printer it is inserted on a slot that really looks like a computer memory,detached it from the printer then use eraser to clean the contact, but before removing it turn off the printer and unplug the power. Be careful when you return it, because it has a positive side and negative, if you inserted it incorrectly, you might damaged the printer formatter.
  • 73 Answers
You would need to replace dimm memory if you have spare one. Or try to remove it and install it again
2 Suggested Answers
  • 526 Answers
SOURCE: Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Posted on Jun 02, 2010
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
Mem test failure replace dimm 1
As the message says, DIMM 1 failed.
It's pretty straight forward fix for a tech.
So the cost should be minimal for the labor and whatever the
replacement DIMM costs.
Jun 28, 2011 | HP LaserJet P3005n Printer
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
The printer states mem test failure replace dimm 0, what is this and how much does it cost?
Dimm 0 is the memory that is onboard the Format board, you can't just replace it like a memory upgrade where you would add another dimm. You would have to replace the whole format board, part number Q7848-61006. cost all depends on how much you shop around.
Sep 15, 2010 | HP LaserJet P3005dn Printer
Jun 02, 2010 | HP LaserJet P3005n Printer
DIMM 0 is the memory slot under the keyboard.
Apr 15, 2010 | HP Compaq Presario 3005US PC Notebook
Problem for HP LaserJet P3005n Printer MEM TEST FAILURE REPLACE DIMM 0
Apr 15, 2010 | HP LaserJet P3005n Printer
Printer hangs and after displays a message"MEM TEST FAILURE REPLACE DIMM 0"
This is a straightforward error message saying that the first bank of memory is defective and needs repalcing. All you need to do is locate the module in the memory bay and replace it with a similar one. These only cost a few dollars so it is avery cheap repair.
Sep 24, 2009 | Office Equipment & Supplies
Hp P3005x hang up!
The DIMM is a removable memory chip installed for adding additional memory. You'll have to replace it. Look in your manual for how to change the DIMM. You can usually remove it and see if the printer works. If you don't see the message again, then you should replace the chip.
Apr 20, 2009 | Office Equipment & Supplies
749 people viewed this question
jasbo
jasbo
