Question about McCulloch Garden
Points gap for a McCulloch 7/10
What is the correct points gap for a McCulloch 7/10 automatic chainsaw?
    President:
  • 2,220 Answers
Air gap for mcculloch mac 140
SPARK PLUG GAP: 0.025 in....AIR GAP: 0.014 ..
Aug 26, 2016 | McCulloch Garden
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
Need sparkplug gap for McCULLOCH 3200
If you go to NGKsparkplugs.com, go to the tab at the top labeled 'part finder', select chainsaw, select MCCulloch, 3200 series...you get that it is .025 and the plug should be a BPM6F if using a regular NGK plug. Hope this helps...
Oct 01, 2011 | Garden
Gap for mag on McCulloch Eager ****** 2.0 chainsaw and stripped threads for spark plug.
14mm thread repair kit will fix the threads in most cases and .025-.030" for the gap on the plug. thanks.
Feb 18, 2011 | McCulloch Garden
Starts when cold but not when hot
Check the air cleaner for plugging. Don't use the choke when it's hot. Check the condition of the spark plug and the quality of the spark which should be blue and snappy. The internal insulator should be a tan color if running correctly (plug gap 0.020"). You may need to inspect the diaphragm in the lower part of the carburetor--it should be flexible with no holes or cracks. Turn the L jet needle CW somewhat until the engine will try to stall when the throttle is pulled, then back it up about 1/8 to 1/4 turn CCW until the engine will 'follow the throttle'. Hope this helps!
Oct 21, 2010 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
My McCulloch Chainsaw automatic Br4eak has jammed. I pulled the break apart and the spring inside the handle has become disconnected. What is the correct place to connect the spring?
The IPL for your saw is probably the only isllustration of what you seek. Use this to construct "YourIPLNumber":
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
Go here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
Find and open the correct detail based on "YourIPLNumber" HTH
Lou
Nov 22, 2009 | McCulloch Garden
Garden Logo
613 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
