Question about Phil & Teds E3 - Charcoal Black Jogger Stroller
My back wheel doesn't clip in. The wheel slides on but the button thing doesn't clip in to anything
  • 419 Answers
When you attach the wheel, there is a v-spring inside the axle, this should pop into a hole on the chassis. If you dont have the v-spring in the axle, then the wheel wont stay on. In this case, I would suggest that you contact 01234 344230 (UK suppliers Out n About) who will be able to send one to you.
I hope this helps.
Posted on Sep 27, 2009
How do you replace a 2007 cheverolet trailblazer steering wheel position sensor
The 2007 and up Avalanche, Escalade, Trailblazer, and other GM trucks changed the design of the bottom of the steering shaft. For no discernible reason, it has a horseshoe cup at the bottom of the shaft that prevents just sliding the old sensor off and putting the new one on like in 2006 and previous models. Therefore the entire steering column has to come out of the truck which is, to say, highly annoying.
Disconnect battery and ground negative lead cable to the frame or leave disconnected for 10 minute to discharge ABS system.
Pull steering wheel ABS cover - 2 small alan wrench holes on either side of the airbag, spring-loaded, pull gently while turning the wrench.
Disconnect both airbag clips (don't lose the retaining clips!) and remove airbag.
Remove lower plastic knee trim (where your knee or shin would touch at the bottom of the kick panel).
Disconnect all steering shaft electrical connectors - there's quite a few.
Under steering column, unbolt upper driveshaft 15mm nut.
Remove 4 16mm steering wheel nuts.
Pull steering wheel out of car, lay on bench.
Remove steering wheel shaft upper protective sleeve (the part that has the horseshoe end shape that prevents the SWPS from sliding off when you're trying to remove it that serves no useful purpose except to turn a 15 minute job into an hour and a half of irritation).
Gently unclip 3 retaining clips of SWPS rear cover (4 o'clock, 7 o'clock, and 12 o'clock on the shaft), slide off, then get a screwdriver in behind the old sensor and gently move it backwards a little so you can get your fingers on it, then slide it off.
Put new sensor on exactly the way the old one was on. Note, DO NOT remove pin until this assembly is back in the car and connected to the electrical harness.
Slide SWPS cover back onto shaft but do not clip into place.
Put steering wheel back in car, connect all bolts and wire harnesses.
Remove pin.
Re-install plastic cover.
Start car, drive to dealership, hook up to Tech 2 and have them run the full SWPS re-learn procedure, which they will probably charge you an hour of labor for anyway, then take your half hour of saved labor money and go buy yourself lunch.
Alternately, save several hours of cursing, make a turkey sandwhich at home to save eating out lunch costs, and let dealer do the whole thing.
Dec 22, 2012 | Chevrolet C1500 Cars & Trucks
How to put steering wheel back on
Are you talking about the spring and C-clip that go on the steering shaft UNDER the steering wheel? There is a special tool required to do that. However, I MADE a tool to accomplish this task by using a short piece of electrical conduit that was jus large enough in diameter to slide down over the steering shaft. (I think it is 5/8" conduit - can't get to my tool box right now to check) Anyway, measure the diistance from the end of the shaft to the groove where the C-clip snaps in. Cut a piece of conduit to this length. Then put your spring on and slide the C-clip on as far as you can by hand. Then put the piece of conduit over the shaft so it is contacting the the C-clip. Then use a flat-washer on top of the conduit and insert your steering wheel fastening bolt into the washer/conduit apparatus and screw it into the shaft. The bolt and washer will push the conduit, which will force the C-clip to slide down the shaft and compress the spring. When you screw it far enough, you will hear the C-clip "Click" into the groove. Voila! your spring and C-clip is installed. Unscrew the bolt and remove the conduit and washer, then assemble the rest of your steering column/steering wheel components.
Dec 24, 2011 | 1995 Ford F150 Styleside Regular Cab
I purchased a older MTD 12 HP lawn tractor. How do I remove the rear wheels in order to replace the tires? Do I need a special tool. I can not see anything to put a wrench to.
theres a screw and a bell washer in the center of the rear wheel , maybe covered by a cap, check this link for a breakdown on that machine as its what I located with the specs you gave http://www.searspartsdirect.com/partsdirect/part-model/Mtd-Parts/Riding-mower-tractor-Parts/Model-33925A/0736/1509200/WL000275/00009
http://c.searspartsdirect.com/lis_png/PLDM/WL000275-00009.png thats the rear wheels diagram
Jul 11, 2011 | Garden
Where should I set the gear and the friction when casually riding my Serene Comfort on level ground?
The above doesn't answer the question as I have recently purchased the same bike. I was wondering the same thing. Should I be at + or - (which gear wheel should it be on 1, 2 or 3?)
Jun 24, 2011 | Diamondback Serene Citi Classic Women's...
We have bought the shopping basket to go underneath the quinny buzz but are having problems fixing it onto the frame?
i had this problem u have to take the front wheel off slide the clip in then put wheel back on and velcro the back on the black parts of the back wheels hope this helps mel
Aug 24, 2010 | Quinny Buzz Three Wheel Stroller
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Jul 04, 2010 | Riccar 8955 Upright Vacuum
The back wheels
There is a cap you need to remove. There is a clip you should pull up on with a pair of pliers. This releases the wheel. Once the clip is lifted the wheel slides off
May 23, 2010 | Baby Trend Sit-N-Stand LX III Plus Twin...
The rear wheel on my dyson dc01 has come off. i have been sent the real wheel fastner retaining pack but do not know what to do with the bits. There are two metal rings and two semi circular black rings....
There is a small groove in the end of the stud on the vacuum that the wheel fell off of.
Slide the wheel back on the stud, put the washer on then put the ends of the half clip in the grove on the stud pushing on the back of the clip with a small screwdriver on the clip to lock it back in the groove. The old parts may be still in the wheel if it rattles. There should be a plastic cap on the wheel like a little hubcap, pry it off with a screwdriver carefully so you can put it back on after the clip.
Please rate this solution if it helps you.. Thank You....
Nov 02, 2008 | Vacuums
Sansa 2 GB Clip MP3
Hard reset the device by slide and hold the power button up for 10 seconds. This will delete anything you have on the Clip.
Oct 10, 2008 | SanDisk Sansa Clip MP3 Player
My scandisk sansa clip mp3 player is fozen at the refresh database screen
I actually called the 800 sandisk number and the guy was helpful (after some annoying personal questions).
Unplug from your computer
Turn off the device.
Push the button down to be in the "Hold" position
Press down on the "center" button (inside the circle)
While still pressing on the center, plug in the device.
Now you should be able to see the device under "My Computer"
Right click on it and FORMAT --YOU WILL LOSE ANYTHING THAT WAS ON IT! But you will be able to use it again. I was assuming all my stuff was gone, it was just copies from my computer anyway.
This worked for me and now I just have put my music back on it.
Hope this helps everyone else! And don't hook it up to a MAC!! Even just to charge it!
Feb 16, 2008 | SanDisk Sansa Clip MP3 Player
Phil & Teds E3 - Charcoal Black Jogger Stroller Logo
116 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Bill Boyd
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
